1 - 13 of 13 Posts
s/v Tiger Lily
Can I just hacksaw through a galvanized mooring shackle. Mine is frozen and I can't get my pennant off. This is the upper shackle on top of the ball, above the top swivel.
Master Mariner
Absolutely. Just make sure you cut where you only have to make one cut, not two.
Reactions: dvuyxx
Mermaid Hunter
Sure you can. How big is it? My 1-1/8" Crosby shackle cost $70. I wouldn't cut that if I can avoid it. We'll see this week. *grin*
Have you tried spraying it with something like PB Blaster and wrapping it in newspaper and plastic wrap for a couple of days? Hit it with a hammer and heat up the bow of the shackle. A crowbar and a big pipe wrench for leverage and you should be able to break it free.
Holding the shackle steady to cut through it will be just as big a pain.
Good luck.
Corsair 24
torch use some heat cycles, bang bang and a big old hammer and wrench
if still nothing use other methods mentioned
Reactions: dvuyxx
s/v Tiger Lily
Discussion Starter · #6 ·
Thanks. I was using a crowbar and an, albeit small, pipe wrench. No luck. I think I'll hit it with PB Blaster and let it sit a day ... but I'll be armed with a hacksaw when I go out to give it a try.
Had an anchor shackle that would not budge even with PB Blaster and leverage. Found a Dremel with a cutting blade made it a quick painless five minute job.
THE BIANKA LOG BLOG: REMOVING A FROZEN ANCHOR SHACKLE AND SWIVEL
I would recommend using a reinforced cutting disk. But, I used a regular cutting disk and it still worked fine. Just bring extra disks in case you break one or two.
Master Mariner
A big enough pipe wrench will turn most any shackle or torque it off. A crow bar or rebar thru it will give you something to pull against.
Sounds really hard to do bobbing around in a dink or on the foredeck of a nice boat.
I have used a hack saw to cut and remove many rusted and of no value anchor shackles. I used locking vice grips to hold the shackle in one place while I made the cut. With sharp blade the soft galvanized shackle cuts like butter.
Barquito
Two huge pipe wrenches. The trick is to somehow imobilize the shackle. If I can get the whole mess into the dinghy, I jam one wrench under my leg. If not, then I jam the shackle wrench on the mooring ball, so I won't turn. Then crank on the wrench on the pin.... Might be a good Idea to put lanyards on the two wrenches!
Super Moderator
A long object like a crow bar goes through the shackle the pipe wrench then spins the shackle against this breaker bar.. If you can bring a 3' pipe that will also fit over the handle of the pipe wrench now you've got enough leverage to break most anything free... Never not been able to get one apart with this method and I help to decommission about 15 moorings per year..
1 - 13 of 13 Posts
