1 - 7 of 7 Posts
I wouldn't use epoxy on trim; it will be nearly impossible to remove if the need ever arises. Use 3M 4200 sparingly; a dab every 6 inches or so. It's only trim and not under load; epoxy is overkill, IMHO.
If your 'trim' is subject to being worked over, IE stomped on or kicked, I'd replace the screws what orignally helped secure the trim. If the area is still dry where the old screws came loose, you might want to seal the old holes so there's no future water intrusion.
1 - 7 of 7 Posts
