Hi all-I'm trying to avoid a halyard wrap situation.
Boat is a Catalina 27 with a CDI 4 furler. I added a spinnaker bail (the one from Catalina Direct) with a block for the spin halyard. All halyards are external. The spinnaker halyard runs from a block at the base of the mast (port side) to the spinnaker block on the bail. Because the shortest path between the two is a diagonal leading slightly forward, the halyard runs past the side of the furler fitting at the head of the jib. When the furler turns, it bumps/drags just a bit on the spin halyard (you can feel the drag it you turn the furler by hand). Flipping the halyard behind the spreader does not fix this issue. As far as I can tell, if the spin halyard ran parallel to the mast on its way up, or was internal, there would be no interference.
I am concerned that the furler may wrap up the halyard and cause all kinds of havoc. I hope this is clear without a pic; but unfortunately I'm down here and the masthead is up there.
So, here's the question-what's the best way to correct the lead on the spin halyard? I have seen halyard restrainers that would mount to the front of the mast. My understanding is that these are generally used to make the jib halyard behave on its way down to a furler; I would think the load on a restrainer and the associated wear on the halyard would be higher in my situation.
It seems to me that a small cheek block on the port side of the mast (just below the level of the spinnaker block on the bail) might be a better way to force the halyard to run parallel to the mast. In effect it would make the direction similar to an internal halyard. It would also have the halyard running through a sheave rather than just sliding through the restrainer, which ought to be better in terms of wear.
What say you? Am I missing something here? Would the halyard restrainer approach actually be the better way? Any thoughts would be appreciated.
