1 - 16 of 16 Posts
Pacific Seacraft 34
Hello all! Best wishes to everyone for a healthy and prosperous 2014.
Here's an update for those interested in our refit. Jo Beth arrived at the Hinckley facility in Savannah, GA in early November. Lisa and I spent the better part of two and a half days getting all the gear off. She's been de-rigged and the mast and boom stripped. The slow and painstaking process of inspections and compromises has begun.
First, I'm very happy to report that by all appearances, we don't have an issue with the mast compression post step. The sag in the cabin sole just aft and to the right [center line] of the compression post step is from a lack of sufficient structure beneath the cabin sole, and here's why: we don't have a standard 34 interior layout on Jo Beth. Instead, we have a U-shaped settee/dinette on the port side. The extra weight of the joinery of the ends which form the 'U', plus my big butt resting on it for 10+ years, seem to be the cause. A lesser sag is also happening at the opposite end.
The bad news is, because of this seating arrangement, some joinery removals will have to done to get the fuel tank out for inspections. More on that to follow.
Cost saved, cost added - sure to become a recurring theme.
The spars and rigging are also getting attention. The running rigging will all be replaced with new halyards, sheets, blocks, etc. The standing rigging all looks good, but tired. It will stand up to another three or so years of coastal service. We'll likely go ahead with replacing everything anyway. The mast is fine; all of the halyard winches require service, as do the sheet winches on deck, but the staysail halyard winch will be replaced. There is some material loss on the winch pads from corrosion and there are cracked welds on each spreader base, all which are regarded as repairable. Minor corrosion is on the mast base as well. Again, repairable.
The boom - now that's another story. I stopped counting the cracks [around the end caps, mainsheet bails, cleats, etc.] at 10. We've been working with LeFiell, the OM, to build a replacement.
The sails are all going to the UK Loft in Charleston, SC for evaluation/repair. I think our genoa is good, as is the staysail, but our main is visibly tired.
We've met with our canvas and cushions shop person, the contractor installing the reverse cycling AC and air cooled refrigeration unit, and all of the yard trades foremen.
Jo Beth will also be painted and re-striped on her topsides, have minor gelcoat repairs made on her house and deck which will then be polished hard, have her mast and boom painted, [the new boom comes painted from LeFiell], get new cockpit grates, and have a myriad of other jobs done. Hinckley says 3-4 months so we're anticipating 4-6. [This isn't a slam against Hinckley - Lisa and I are well acquainted with what we affectionately call 'the boatyard follies.']
Lastly, we're redoing our blog. Stay tuned for more.
And a Happy New Year to you.
I was hoping you would keep us sister ship owners updated on what you were doing with JoBeth - obviously. a labor of love.
Looking forward to meeting you shortly and getting more insight on the project.
Hugh Macnaughton/Ariel
Pacific Seacraft 34
Discussion Starter · #4 ·
Hello Hugh,
Welcome to the PSC forum! There's lots of good information here and folks here. I'm sure you'll find it very helpful.
I will see you later in the week -
Pacific Seacraft 34
Discussion Starter · #5 ·
What did they quote you to paint the mast?:)
Well, it's being revisited now, given that the replacement boom will come from LeFiell painted and that we have some repairs to do on the mast. Then, there's the issue of matching the boom and mast colors...
However, the original quote to paint both the mast and boom, including unstepping and stepping, undressing, and reassembly, was $4,975.
Maine Dub
A yard up here quoted me 12000 for mine. I declined. I will touch it up with a rattle can. Cheers Al:)
We had our mast repainted 3 years ago. We paid around $5k for the soda blasting and paint. It looked awesome for the first year, but then it started to bubble in places - mostly at the ends and around welded fittings. We were careful to ensure that all the fastners were coated with Tef-Gel and the mast step is aluminum to aluminum contact so it isn't galvanic corrosion (at least not entirely). The yard warned us that bubbling/flaking was a real possibility beforehand. They even refused to re-paint our bomar hatches and insisted that we have them powder coated instead because of this problem.
In the end, I wish I would have saved the money and left the mast and boom alone. In another year or so it will look no different than before we painted, maybe even worse.
Pacific Seacraft 34
Discussion Starter · #8 ·
Interesting. Our winches were put directly onto the aluminum pads welded to the mast, and that's where our worst corrosion is. Clearly, bronze touching aluminum is bad for the aluminum. When the winches go back on, they'll have nylon pads [or something similar] to insulate the aluminum from the bronze, as will anyplace where aluminum contacts other metals.
Tef-Gel will be used with everything that's bolted, screwed, or otherwise fastened to the mast and boom. I'm very surprised to hear about the mast/boom paint blistering/bubbling after just a year. Powder coating is a good way to go. However, if the coating is ever compromised, I understand repairs can be difficult to achieve.
I'm glad we don't have the old aluminum framed Bomar hatches to deal with though. We replaced those years ago with another Bomar hatch, but with nonmetallic frames. They've been stellar.
We just put a fresh powder coat on our boom here in San Diego. Came in around $400. Not too bad, but we did all the work ourselves and dropped it off at the oven. When we remounted the winches, we used PVC tape like Shurtape as a backing. Also filled the new taps liberally with 4000 before rebedding the machine screws. Hoping that keeps corrosion to a minimum.
Pacific Seacraft 34
Discussion Starter · #11 ·
I can't recall which Bomar hatch it is - it's been about 8 years - but it is a Bomar. I think they are the Cast Series 100 hatch. (I was incorrect when I said they were plastic in my earlier post - my wife corrected me and I have no idea why I thought they were. I should know better!)
The Pompanette/Bomar site: Bomar - Home
I'll see if I can dig up more specifics.
Hey this is Rich from SV Hush across the river from you guys. I saw the post about the mast painting and I too am a bit concerned about having that done. Unless the mast is completely stripped to metal then etched then primed with zinc chromate, painted with a great paint then everything reattached perfectly, you will have pitting. That hole nobel metal thing is a pain the the kiester.
Anyway, our refit is coming along great at Sail Harbor. Steve and the crew are really paying close attention to detail. Worked on Hush this weekend and finally refinished the insides with fresh oil. WOW what a difference it makes. I have the chain plates (from the factory), standing rigging (from the factory) and other goodies ready to go back on the minute our final coat of paint is applied.
As a side note, I popped the old Datamarine Transducer out to make room for the new Raymarine 319. Cannot tell you how much I hate 3M5200. They bedded the transducer in this stuff and made it pretty much bomb proof. It took me, a drill, a screwdriver and a hammer to break that beast out of its hole. When done felt like I did an MMA Fight then ran a marathon. We are not going to use 5200 on this transducer....4200 or some other more user friendly sealant/adhesive is coming off the bench for this one.
Anyway, we are making progress...slow and steady progress. Might see you out on the water real soon. Take care!
Pacific Seacraft 34
Discussion Starter · #13 ·
Rich,
Good to hear from you. I was in Sail harbor the other day and saw HUSH was primed and close to being painted. I'm glad things are moving along for you two. I had no idea Steve had gone from Yard Manager to yard and marina owner! That's great news! I've known him form our days back at Isle of Hope Marina, more than 10 years ago now. He's a good guy, a straight shooter. HUSH is in good hands.
Even if everything is done perfectly, whether it's painting the mast & boom, the hull, re-powering, adding new sails...it all breaks down eventually. Mother nature and the laws of physics will always win. I've got confidence in the guys at Hinckley to do the work right - and I know from past experience, they'll step up and take care of problems. Still, I hear you - and fingers are crossed!
I'm surprised a transducer was put in with 5200, but much of the time, whatever happens to be close at hand is what gets used in yards and by boatbuilders when it comes to caulks and goops. (I think our monkey fur might have been put on with 5200!!) Did you use the de-bonding material that's available for 5200?
Pacific Seacraft 34
Discussion Starter · #14 ·
Another refit update posted on the blog - link below. Things are moving along!
Hey this is Rich from across the river in Savannah. An update on Hush...We managed to escape to and head south this past week. Hush has all new standing rigging, chain plates, sails, epoxy and bottom paint, and new electronics.
Things at Sail Harbor got a bit hectic at the end and a few fine details were nearly missed. Steve is a really fantastic guy to work with, he just needs to write things down. In the end, I got a fantastic job at a reasonable price and developed some very good friendships.
The sail down to Florida went down without a hitch. A bit of motoring on the ICW and a couple days standing in the rain and we are home.
Hope your refit is finished soon too.
Pacific Seacraft 34
Discussion Starter · #16 ·
Thanks Rich - glad to hear you're out of the yard!
Steve and the crew at Sail harbor are good guys and I'm glad your experience there with HUSH was a good one. I've know Steve for 10+ years now, but you are right - Steve does need to write things down. However, he'd likely lose the paper!
Take care and more news on Jo Beth will follow!
1 - 16 of 16 Posts
