Well I just couldn't take it anymore. It got to 35 degrees so I uncovered my new boat (tub as some would say) and moved it into my garage to start putzing on it. I have a question on my Harken Traveler because right now I am not impressed (at least on my P165). I put the rudder/tiller on and the tiller either has to go way above the traveler or underneath it so...you either stand up and way up to steer or you have to sit down and not up at all. Not impressed so here is my question...am I missing something or is this a normal issue with having one and are they really worth it? Without the Cunningham the tiller would go inbetween the main sheet lines and have more up and down movement availability.
Next questions is:
Previous owner has a clam cleat on each side of the cockpit on the coaming which he used for the 150 Genoa--makes sense. I believe the boat came with cam cleats on top of the cabin and pulleys down stream which according to the manual (and You Tube videos I have watched on the P165) these are used for the jib lines..makes sense again however, PO had one marked Cunningham and the other marked downhaul...sort of makes sense. I am trying to figure out what he used or how he tied down and constantly trimmed the jib with these cam cleats being used for the Cunningham and downhaul or does one really have a jib line in their hands at ALL times?
As far as the topping lift..still have to figure that out and the boom vang as well. The You Tube vidoes with others sailing the 165 show the boom vang line just hanging into the companionway area so I am assuming it has a block lock somehow. REMEMBER, still learning!
I need to figure out not only how he or how I should control jib lines but also the line(s) to reef.
Being a newbie (and reading several articles stating the 165 sails pretty nice with just the main up), I am sure my first sail will be only with the main.
Next questions is:
