Just joined long time lurker
Grown up kid who used to sail with parents
Trying to trade 15,000$ 200mph+ plus 1978 scirocco turbo
drag racing classic Vw
For a live aboard cruiser and bug out
6montbs of nonstop work to his hot rod
Plus 30 years of documented work by a famous tuning company
36 year old hot rod , Turbo alone cost 2100$
Pink slip in hand from 1985 has only had 2 owners
Me and a former racer
The hardware:
2.0 twin cam 16v 87 head + newer 97 2,0 block
Kevlar 1.8t timing belt
With new headgasket, and arp headstuds
8:1 compression
T77 turbo can make 1000 whp if wanted
I have new turbines in bubble wrap to make 1300hp
1990 corrado transmission
1990 corrado computer and stage 5 chip for thunderbird turbo injectors
Cable shift conversion
800 hp intercooler
All 2.5& 2.75 " intercooler tubing
Copper oil lines for turbo feed and return
Zinc plated oil pan and motor mounts
Firewall modified for hydraulic clutch transmission
Hybrid motor mount brackets to use the newer trans
Is installed
Vr6 clutch, tdi flywheel
Welded lowbroe 500 hp axles
Trans has stock LSD shifts great
All engine parts polished or painted
All sway bars, strut bars and etc installed
Poly mounts bushings and pieces
Brembo brake rotors slotted and drilled
All wheel disc brakes
No cracks in any glass
NHRA roll cage installed front to rear
Sparco seat
The car: 1978 scirocco blue and yellow
With flames hand painted and hand made louvers in hood
3000$ paint job
2000$ cage
Aftermarket fuel cell same capacity as stock
500 hp walbro fuel pump
Billet aluminum fuel rail
3.5 bar fpr
Tial bov
50mm stainless wastegate
On and on
Sick show quality drive to drag strip and waste the big block v8s
Stock na ran 11s turboed 9's capable of more
Road racing car converted to cruiser/bruiser
All glass windows installed and entire wiring harness from 79
Donor mostly new rubber seals new windshield etc
Originally featured in magazines from 78-85
Went on the classifieds & found it confusing
Did not see a way to start a thread there
On this seperate forum there is a new post icon on top left
But in classifieds I saw nothing
Will move this to trade forum later
Willing to travel to pick up boat
Car is in northwest and must be picked up
The hardware:
8:1 compression
800 hp intercooler
Is installed
Sparco seat
3000$ paint job
2000$ cage
3.5 bar fpr
Tial bov
On and on
