Help!, Does anybody know this boat?
1799 Views 11 Replies 7 Participants Last post by  Honolulu
Aloha from Honolulu, I rescued this little 12' dinghy from oblivion, it lacks a centerboard and a few other smaller parts but I do not even know the name of the design let alone where to get parts or specs for it. It has a wooden mast and is fiberglass. Does anybody have any ideas? Thank you for any info!!
See less See more
4
1 - 12 of 12 Posts
At first glance it looks like a Kite. That looks like a free standing cat rig which is how the kites were rigged.
The hull also looks like a Flying Junior, but there were a whole lot of small boats that looked very similar. I would suggest that you look at the transom and try to see if there are VIN numbers that might give a clue.
Thanks for taking the time to respond Jeff, I will search the net for pictures of the designs you mention. Regarding serial numbers, or for that matter anything stamped on this boat there is nothing left, the sail has a "K" and the number "145", but I have the feeling that it may not be the original sail or even an original replacement sail for this boat. When I search for a "K" boat on the web I only came across the "K" series but they are very different from this one not to mention the fact that most if not all of them seem to be wooden hulls and this one is fiberglass.
This one also has what it seems to be a water ballast (?) since it has a hole that can be plugged after filling it up, this is on top of the two holes that can be seen on the transom.
Hector from Honolulu
I would guess that this is not a water ballasted boat but has some airspace between the hull and the deck/floor insert for floatation, etc. and that the holes and bungs are to drain any water that happens to leak in.
If those are state registration numbers on the bow, the Hawaii DMV(?) will have the owners information on file.
Good point, I will check with them on Monday.
That is what I thought at the beginning but the way that it is designed is kind of typical of water ballast opening that uses one of those expandable rubber plugs. I am uploading a picture for you to see.
Hector
See less See more
Aloha Jeff, I took a few more pictures with the mast on maybe they are more clear. I also check pictures on the web for the 2 designs that you suggested but no luck.:-(
PS The beam is 64 inches and the LOA 140" without the rudder.
See less See more
4
This is obviously a catboat. So, why not just measure the luff (from where the boom attaches to the mast up to the top of the mast minus a bit for attaching) and the foot (length of the boom minus a bit for attaching) and contact some used sail lofts and see what they have in those sizes.
I just throw some guesses
So far the Kite look good.
My friends and me play a game called; Whatisit? :confused:
Normally we find things no one ever seen and see if someone guess what it is. :rolleyes:
I have seen everything from a Domaflachie to a Thingamajig (My spell checker actually show this as correct spelling). :laugher
So, anyway, with formalities explained. I start my thoughts on this. :p
First look very good on the Starboard (Right) transom Outside. Use a very bright light, if it been painted over the years the HIN (numbers) may be filled in. If you can see something you may be able to lightly sand (800 grit) and see better.
Boats built before 1972-1973?? Somewhere around then, may not have numbers.
I almost want to say it a Sears, but, I not think those had much of a double hull type setup. I may be wrong.
I know right around the 70's many companies were trying to get into inexpensive sailboats as it was an exciting prospect.
I think Montgomery Wards even had some fiberglass fishing boats, not sure they had Sails. I pretty sure Sears made a sailboat. ***I may better add, Sears and others had the boat made for them, I think Chrysler made Sears' outboards.
AMF, but, I not think they had a cat boat.
Being in Hawaii it may be an Australian. So may search that.
Heck, Western Auto had an outboard motor, maybe they had a boat too. :eek:
I am interested to know, hope we can all brainstorm and someone find the answer. ;)
See less See more
That is a good idea thank you. :)
Hector
1 - 12 of 12 Posts
