I recently just purchased a Parker Dawson Poacher 21. I have a thread in the Introduce Yourself section if you would like to read more.
So anyway, the retractable centerboard seems like a blessing and a curse. It's great in that the boat has a super shallow draft and is easily trailerable, but since the center board is swinging in the cabin on a winch, it has the opportunity to bang up and damage the trunk or itself during transport or if the board isn't deployed all the way. I think that even when lowered, and the boat is run aground, that the centerboard can swing back and up inside the trunk. Probably even under way under normal conditions it will bounce around a bit.
Well, it seems that the previous owner must have run it aground a few too many times. You can see in the pictures below, that the intersection of the trunk and the hull has some blunt force trauma in the form of two holes, one towards the bow which where you can see some sort of resin mixed with filler behind the laminate, and another towards the stern where you can see some filler to starboard, and a wet bit of balsa core to port. Unfortunately, the boat has been out of the water for at least two years now, but still has sopping wet wood in this location. I poked around a bit and tried to see how deep I can poke through the soft wood and the damage felt limited to just one side. I guess I'll have to sand the bottom paint off first to see how bad of a shape the gelcoat and laminate are in this area.
I read the West Systems fiberglass repair manual and was going to proceed with the pegboard hole drying method. Maybe hook up a vacuum pump to make it go faster. Then, as the manual says, I'd fill the holes with epoxy and try to fill and gaps that delamination may have caused. Do you guys think this will be good enough or will I have to cut larger patches to see if core replacement is necessary? I'm afraid that if it's still this wet, there may be a lot of rot in there. Is there a way that I could reinforce this area better as well so that this damage doesn't happen again?
Once this is fixed I'd love to install some way to clamp the centerboard down when it's lowered, as well as a way to keep it from banging around in the trunk when it's fully retracted. This boat will be trailered whenever we want to use it as we have plenty of boat launches in the area.
Below at the link is an shot of the centerboard and trunk from within the cabin (not from my boat, but a Poacher), and images of the damage under the boat.
