1 - 8 of 8 Posts
Put my battrees(the RI way to say it) today (one new one) and now I have to hunt down what I am guessing is a bad ground on the house bank. Main power indicator bleeds on but is really dim and I know the battery is good (brand new 13.8 volts from my tender to be sure)
I will have to bring my multimeter to the boat tomorrow afternoon but if anyone has a good starting point (from experience please) I am all ears:)
It was fine last year when they were removed in NOV.
One of None
Hunter 34
Check every cable terminal Blu! I'm reworking my whole battery system and I've found 3 or 4 that just came off with a twist. Most of the older boats did not use tinned marine cable (guessing)
Discussion Starter · #3 ·
Check every cable terminal Blu! I'm reworking my whole battery system and I've found f 3 or 4 that just came off with a twist. Most of the older boats did not use tinned marine cable (guessing)
Good guess, they are pretty old...I will check those first
Discussion Starter · #4 ·
Quick update -
It looks like the contacts on the 33 year old master breaker were dirty. I cycled it a few times and once I fired up the engine it was all good again.
I am splashified!!
Super Moderator
I will say it once again, pliers and hammers are NOT crimp tools......;);):D:D
Discussion Starter · #6 ·
Update....It turns out it didn't fix itself
I have a strange 1+ volt drop when I flip the house breaker, even with all the fuses pulled. I even bypassed the main breaker and still saw the drop so I know the draw is in the bank somewhere.
The only thing that I need power at the house bus for are tunes and nav lights as I really don't overnight. To be safe I am just going to put a temp panel in with a fresh ground, pull the hot from the old panel and wire in what I need. Resale is not really a concern for a boat in this "value" range anyway and I really don't wan't to see my prop go away to electrolysis.:laugher
Keep in mind that there is nothing particularly special about ground and the positive side is equally important.
If you're able to run a new ground as you say, why not just run both positive and negative. Perhaps in the process you'll find the problem too.
Or as a better debug alternative get your multimeter across the negative and positive paths. I.E. put one side on the battery + and one side at the positive on your panel, and do the same (but opposite) for the negative side. If you have a bad connection one will have a significantly larger voltage drop than the other. The larger voltage drop is the problem.
Discussion Starter · #8 ·
Another update...Feeling pretty foolish here:rolleyes:
I should have fallen back to my old school training (I was a missile technician after all).
It turns out that I had dirty connections at the battrees (RI lingo again). I wasted a solid 30 minutes trying to fix something that wasn't broken:mad:
1 - 8 of 8 Posts
