1 - 5 of 5 Posts
I'm redoing this boom outhaul and am also new to sailing bigger boats. I am just curious how much do you take in and out on a mainsail outhaul. I figure around 6-8 inches? I'm talking about the aft end and how far the car (or whatever) moves. Obviously it needs to pull tight but how far would one ever let it out?
6 inches or so sounds right to me.
Ditto on the six inches. Your outhaul "play" won't be much more than your "E" dimension and if you have a bolt rope, you will not get more than a couple of inches of "ease". I trim a loose-footed carbon mainsail on a Cal 40 and never ease more than six inches and usually around four. It is amazing how dramatic the impact of just moving the outhaul an inch.
6" maximum is about right.
How much to take in or let out? ..... Go onto a closehauled course, then ease/tighten as you watch your Speedo; the 'correct' outhaul setting for the current wind/wave conditions is where you get the maximum reading on your Speedo.
Flat sails for 'speed' sailing in flat water (outhaul tightened) - "high gear";
Full draft for 'punching' through waves (outhaul eased) - "low gear".
1 - 5 of 5 Posts
