1 - 20 of 21 Posts
Glad I found Sailnet
I just bought a very inexpensive battery maintainer from Harbor Freight to charge an extra wet-cell battery that I have. One of my intentions is to test the battery capacity this winter.
The battery is a group 27, combination starter/deep cycle battery. It is in the garage, where it will be between 50 and 20 degrees this winter. Before applying the charge, I checked the specific gravity of one of the cells and it was well into the red on the gauge. The battery needed to be charged.
The charger is spec'd for 1/2 amp and to maintain the battery at 13.2 volts. I've had it connected to the battery for a week now and the voltage is consistently maintained at 13.2 volts.
First question: At 13.2 volts, is there a limit to how long I can keep it on the charger?
After the week of charging, when I take the battery off the charger momentarily, it shows 12.5 volts. (Haven't re-tested the specific gravity yet.)
I'm planning to do a load test on the battery with a 12v, 25 watt element that I used for the wind generator's dump load. (Meaning about a 2 amp load.) I figure I'll take 25 amp-hours out, let it sit for a day and check the resulting battery voltage and specific gravity. In this way I'll know how many amp-hours the battery is still good for.
Second question: Anyone see any issues with my battery testing plans?
Regards,
Brad
(I have a fantastic, Victron battery monitor on the boat, but I'm doing all this at home. I'll just keep an eye on the voltage across the 25 watt element and use the V=IR equation to track the current usage and get to a fairly exact 25 amp-hour draw-down.)
A few thoughts:
1. You could leave the battery connected as long as you want @ 13.2VDC.
2. Problem is, even at 13.2VDC the wet-cell battery will sulfate, though slowly.
3. Your reading of 12.5VDC after momentarily disconnecting the battery charger is pretty low. It should be at least 12.6-12.8VDC.
4. This leads me to suspect that your battery has lost significant capacity and is in need of equalizing. This requires a 15.5 to 16VDC charge for several hours, maybe repeated a couple of times.
5. Combination "starting/deep cycle batteries" and "no maintenance" flooded batteries are not a good choice for a boat.
6. Your plan for a timed discharge is unclear to me. Batteries are generally rated at the 20-hour rate. The way you test them is to apply a resistive load roughly C/20 until the voltage is drawn down to 10.5VDC. It should take ~ 20 hours if the battery is near 100% capacity. By measuring the total AH drawn before the battery reaches 10.5VDC you'll know its real capacity.
7. In any case, you'll learn a lot in the process. See if you can borrow or acquire a charger capable of doing an equalization charge. You may be able to rejeuvenate the battery a bit.
8. Battery monitors like the Victron on your boat can be great, but they can also deceive unless calibrated and tested regularly.
Good luck,
Bill
We used a lot of group-27 *marine deep cycle* batteries in powered wheelchairs; always tested them with a Load Tester. The combination batteries did not hold up well at all (some of our customers tried pinching pennies -- didn't work out for them).
Sounds like you need to give it a real charge before you put it on maintenance charge. You have to test specific gravity of *all* cells -- they should be about equal -- if not, you could have problems with plates or separators.
LOAD TESTER
I don't know about freezing batteries (I'm in Florida) , but it sounds like a bad idea; maybe the trickle charge will keep it warm.
Is the battery in a box, in case of an overflow? Isolated from the floor? .....a concrete floor can drain a battery pretty quickly. What kind of ventilation do you have in the charging area? A little hydrogen, a little oxygen, and a spark can do an amazing amount of damage, like 'take the roof off your house' bad -- no wonder they used it to fuel the Saturn V to launch Apollo to the Moon.
Lots of info, including temperature correction charts, here.
#include [ std-disclaimer ]
islander bahama 24
I have had that same charger on my GRP 27 for a year without incident still has same ah it had then recently tested with a tester similar to the one pictured I use it as a backup to my 8d on my lil islander
Battery cases are plastic now and leaving them on a concrete floor will not have any ill effects. Before the plastic cases it was an issue - many decades ago.
As long as the battery is fully charged it will not freeze - at least not until it is really, really cold.
From Trojan:
islander bahama 24
From Trojan:
I have had a battery in my car freeze in Wyoming at 30 below and I know it was a good battery so from my personal experience I would assume that the trojan data is slightly biased in their favor IMHO
This link Can a Car Battery Freeze? - KickingTires states -76F for a fully charged battery, as do other links. It all depends on the specific gravity of the electrolyte. Your battery was probably not fully charged.
A few thoughts:
Good luck,
Bill
Why would a combination deep cycle / starting battery be a bad choice for the starting battery on a boat?
islander bahama 24
Ithe battery was a 6 month old interstate car battery in a Subaru I had just driven from bremerton was to my sisters in burns wy it was so cold taters in the kitchen froze where they touched the north wall it was 70 plus in the mobile home at that time didn't check the specific gravity just started the car and the battery thawed out while I drove back here to the base after Christmas in 1990 just my experience and I don't ever want to experience it that cold again
Super Moderator
Your battery never likely froze it just lost the ability to crank your engine at that temp.. In cold temps the battery looses deliverable cranking ability as well as usable Ah capacity. It comes back when the battery warms... If batteries froze at -30 it would be real tough to live in Fairbanks, where I was born....;)
bene505...
Put the battery on an orthodox charger and watch the current draw. It is not an easy call, but leave it on there until it is fully charged. Use a hydrometer if you must. Watch the electrolyte level during the charge. Top it up if it drops too much.
When it is fully charged, then put it on the trickle charger and maintain the 13.2 V you describe.
Personally, I would put it back on the main charger about once a month to bring it back up to full poke.
islander bahama 24
Just a lil side note Fairbanks did not see any sub 0 temps in 2014 at all.
Old enough to know better
Just an FYI I bought the same charger to hook up to my Miata off season, and it fell apart when I tried hooking it up. So I would not use it very long term, not for the damage it may do to the battery but to your house! I had bought mine a few years before and never used it, so I could not return it.
islander bahama 24
Tell HF ppl you got it as a gift they will replace it without a receipt unless it really looks like it has been used hard ( at least that had been my experience with an inverter that died after a year of intermittent use had the box they exchanged it no questions) YMMV
One of None
Hunter 34
From Trojan:
I like this! I've never thought about why of if batteries freeze but now I know, it's not that cold where I live!
13.2 sounds good, offhand, but I'd check the battery maker's own specs for the optimum vs allowable "float" voltages for the battery to be certain. And check the voltage versus temperature, to make sure 13.2v is within the acceptable range for the temperature of your storage area.
But since it is Horror Freight...please doublecheck the actual output voltage, under load and no load, to see what they've sold you.
I haven't used that charger but one of their "free" voltmeters was miscalibrated, over 1/2 volt off at 12 volts. One of their polishing wheels came without a bolt, necessary to install the handle in order to use the thing. And one of their "jump boxes", recommended as a great value because of the 17AH battery inside, came with the battery unsecured in the housing and the built-in voltmeter simply not connected at either terminal.
HF, the folks who help us to remember, "Trust but Verify". (G)
OTOH, I've had nothing but great results with their breaker bars, although, I'd never try to load them up all the way.
Super Moderator
Weird my info came from the NOAA weather
Yes that would be very weird. I don't think there is a winter where Fairbanks never got to -20F let alone never below 0F. Having lived there and experienced tires that have continual flat spots, windshields that crack if you turn on the defroster too suddenly and spit that freezes before it hits the ground all I can say is it gets cold. My dad was there in 1961 or 62 when it hit -60F. But most winters see at at least a few days below -40F and some in the -50F range..
1 - 20 of 21 Posts
