How much bleach is needed to sanitize and to provide ongoing disinfection has been flogged to death here and by EPA/WHO/ANSI. But there is always concern that bleach will slowly eat away at aluminum tanks. No question, it does, I've run the coupon tests. If there is a solid residual in the tap water, it is enough to shorten the life of a tank in regular use. Hydrogen peroxide is suggested as an alternative; it is often strored in aluminum tanks. Additionally, it will neutralize bleach/free chlorine in water, converting it to less agressive Cl-. It would be interesting to do some corrosion tests on this effect... but niether EPA or WHO consider it a valid disinfectant and I can find nothing authoritative on the web. Perhaps my Google Fu is weak.
My understanding has always been that for sanitizing it must be used nearly straight up (3%). I've read that up to 1000 ppm is authorized for drinking water (EU chemical company), but that would be rediculous in use, requiring a case per fill-up. A single bottle would only reach ~ 30 ppm, and I'm pretty sure that is not enough unless combined with other treatments.
Any authoritative refferences? "I've been doing X for years" does not count--though I'm sure you have, others have been doing nothing and remained healthy. There must be some agency that has published something.
