1 - 17 of 17 Posts
Hull Number 33
Dear Learned Colleagues,
In an exuberant show of patriotism on the 4th just past, I rigged two flags from the wire main halyard of my Columbia 36 joined by a "D" ring shackle between the bottom and top grommets of the flags with a spinnaker sheet securing the bottom grommet of the lower flag to the coach roof hand rail such that they flew mid way between the mast and the topping lift.
Another flag was flown about midway ( approximately spreader height) on the jib halyard with a down haul secured to the jib tack.Since we were in the slip and not underway, to be courteous to our dock mates, I secured the jib halyard tail to the port lifelines to keep it outboard of the mast to prevent it from slapping in the 10-15 kt. breeze.It's a rope to wire halyard.
Longer story short, the "D" ring fails, the top aft flag rises,wraps the jib halyard and then jams at the masthead sheaves. The flag then proceeds to wrap further around both halyards freezing both.
I don't have mast steps and wonder how would one go aloft, short of shinnying up the mast, without a halyard for a bosun's chair or to raise a sailtrack climber?
Standing Rig? Boatyard Man Lift? Power to a bridge at low tide? Hire a mechanically inclined monkey and give him a down haul to carry?
Any suggestions welcomed.
ASA and PSIA Instructor
You could try rafting to a smilar size boat...get hoisted up their mast to where you can reach the mess you have...I gues a question would be whether you can untangle things from a few feet away...
Hull Number 33
Discussion Starter · #5 ·
Thanks to all for the suggestions.
I've got a tabernacle mast, but lowering the stick in a crowded marina (i.e. across the dock and potentially onto someone else's boat isn't appealing) or turning the boat around and lowering it into the fairway with it still about 7 to 10 feet off the water would only work if another boat with about that freeboard could manuver close enough to the masthead.
1977 Morgan OI 30
bridge ladder or crane
If you can get safely near a bridge or use the yard crane that may work. I actually used an extension ladder to put a radar up...don't tell anyone! Are you friends w any firefighters? I know these all seem ridiculous...but
Hull Number 33
Discussion Starter · #8 ·
Actually the ladder idea doesn't sound bad if it could be secured to the spreaders, held secure at the footing by genoa sheets cleated off the winches, and my offshore harness and tether clipped off on the rungs.....hmm. Then armed with a boat hook we might be able to untangle the Stars & Stripes sufficiently to at least free the jib halyard (which is still reaved and has a downhaul rigged.)
The boatyard I'm certain would love to hoist the mast ( and my wallet) but all they really need to do is carefully lower it forward on the tabernacle while the boat is side tied to the dock. I'll have to ask what the cost is for crane time. A cherry picker that can reach about 35 feet would be easier.
My old boat is like a milk man's horse, you get her near the barn ( a boatyard) and she wants to stay.
Again thank you for your collective wisdom.
Sometimes, the yards will attach a bosun's chair right to their crane and lift you up. It depends on the yard though. With today's insurance regulations and Osha and yada yada, they may or may not do it. Or they may only lift their own personnel in which case they will be expecting reimbursement. I did this once when I was much much younger.
<O:p</O:p
Know any tree pruners with a bucket truck? It would cost you far less than pulling the stick (sub-$100 for certain). I'm assuming a truck could get close enough, of course.
What about rigging something akin to an adjustable backstay's tackle on your stays? Except the "fixed part" would be your chair instead of the transom.
Basically you'd put a wire block on each of the fore and back stay, and then run a block and tackle between them. You could hook your chair onto one of the ends of the block and tackle, and then haul yourself up with the free end. The mechanical advantage of the whole setup would be that for your block and tackle, divided by the sum of the sines of the angles your stays make with the deck, or something like that.
The only problem would be what to do when you get to the spreaders. You could rig two such tackles and swap them at the spreaders. You'd probably need somebody to help you with that; if you were going to do it alone, pre-rig the one that goes over the spreaders and carry the free end with you as you ascend.
This actually sounds like fun. I think I will save up for all the components and give it a try :)
A couple prusik knots can get most people aloft pegboard style, once the halyards are loose they can be used to get down easily. (can use the prusiks to get down also) Make the loops long enough to function as footholds, and use a harness with a loop around the mast.
Bring enough loops to make it past the spreaders.
ken.
Somewhat Senior Member
Here's a solution I observed this past weekend. On the dock opposite my fairway a similar situation arose when the Capt. ran a line of burgees up the mast with halyard and downhaul. The line broke and the halyard was wrapped and flapping with some penants still attached. He taped two boat poles together to acheive length and then ties on a fishing lure leaving a short amount of leader. He then was able to swing the lure and after a few attempts snagged one of the penants. He then unwound and drew down the halyard. All is well at no expense.
Just a thought...MGM
1 - 17 of 17 Posts
