1 - 3 of 3 Posts
· Bruce Roberts 25'
on my 29', the Hull ID is hidden but visible inside the port locker in the cockpit. I had to hang my head in there with a flashlight and look up inside the locker to see it. It was almost at the hull/deck joint and written on the hull itself, and not the transom. Maybe the 25 is the same?
· Custom Member
HINs were only required beginning in 1972, so it may or may not be there. If it is there, look on the starboard side of the transom for a small inset rectangular panel.
That said, the hull number listed in your registration is about right for a 1971 Cal 25. Good bet that's the correct hull number.
1 - 3 of 3 Posts
