- Reaction score
- 8
Ok so I have the original trailer that came with my 1978 Venture 21. The axle broke. It was a 2500 lb. square tube axle.
I ordered a round 3500 lb. axle and new springs. When installing the new axle I realized that the old axle was mounted below springs and the new was set up for above the springs.
The space did not allow above spring mounting because of the keel hitting the axle. So I flipped the axle and mounted it below the springs. Now my cambered axle bend is facing downward. I spoke to the trailer axle manufacturer (******* trailers) and they seem to think because I increased the weight capacity of the axle over the amount of the boat that I should be fine.
My question is exactly that, do you think having the camber flipped even though I am no where near 3500lb. will cause an issue???
