1 - 8 of 8 Posts
Firstly I wanted to say I'm very excited about joining this forum and I hope that it's as good as I've been told.
I picked up this half finished little boat up from my grandparents a while back and now that school is out for the Summer I thought fixing it up would be a great idea. It is a small little boat curved at both ends and is made of plywood coated I'm fiberglass. All I've done to it so far is sand the wood and make it a little cleaner. I'm planning on sanding down the external fiberglass and replacing it as well as reprinting the inside of the boat. I've currently run into two possible problems: both ends are pointed so how do I mount a rudder? And there's no bracket for a sail or a sail so I don't know how much sail I need and how to mount it. Here are some pictures:
One of None
Hunter 34
What you have there is called a pirogue or a flat bottom canoe. most common in the deep south. Sometimes they are called dories (wrongly)
Also if that is the sail laying there it looks like it was used like a sailboard (stand and hold the sail using body weight to steer and sail.
This company specializes in them. Cajun Pirogue Boat Kit Photos
To mount a rudder on a canoe or double ended type boat you need rudder fittings called pintles and grudeons or strap type pintles
It must be heavy with glass on it. Glass was probably not needed for a plywood boat.
Hope this helps!
Discussion Starter · #5 ·
thanks for the advice guys. Rudder attachments down now and now i only need a rough square foot of sail estimate. think a sunfish sail would work?
also the boat is surprisingly light, i can lift it with one arm( one point resting on ground)
1 - 8 of 8 Posts
