Recently I had an impeller come apart. My engine had started to smoke more than usual and the water flow through the exhaust had diminished. While checking the impeller I noticed it had several vanes torn off and the outflow to engine fitting in the pump was plugged with debris. After changing the impeller I fired up the engine and although some water was coming out with the exhaust not the amount I was used to seeing. I looked at the water pump and it appeared to blow out a seal allowing a large amount of water to escape through the seal. I changed the seal, same deal. I am assuming that when the impeller came apart that some debris must have lodged itself down stream creating the pressure that causes the water in the pump to blow by the seal. Question, what is the operating procedure for clearing debris,,,,,,???? I'm going to start with the line which leaves the pump and goes to the engine, tracing from there whatever I can,,,,,,,any suggestions??
thanks,
Rick
thanks,
Rick
