1 - 7 of 7 Posts
Hi :)
I am hoping someone can help me with the info on two questions. 1) what after market/third party impeller(s) can I use on the 3GM30F? 2) is the raw water pump and coolant pumps both use the same type impellers? Thank you very much!
Val
· Super Moderator
Farr 11.6 (Farr 38)
First of all there are two different model raw water pumps and so two different raw water pump impellors that were used on the 3gm30F so you need to know the serial number of you engine. (I have one also). One is slightly wider than the other. I am told that the narrow impeller doesn't pump enough water in the wide pump and the wide one burns out in the narrow pump and the pump tends to leak and score the cases.
Bayshore Marine in Annapolis carries complete Yanmar parts.
Discussion Starter · #7 ·
Just called them and placed the order. Wow!! I wish there were more stores like this. Thanks!!
1 - 7 of 7 Posts
