1 - 10 of 10 Posts
My 1978 fixed ports are leaking and one is cracked. I can see that the inside frame rivets have to be drilled out and that will remove the frame. But the plexyglass looks to be mounted in a recess in the cabin top from the outside. Is it just setting in the recess and held in w/ adhesive? If so, then do I need to even take out the frame on the inside? There is not a frame of any type on the outside. My thoughts are to replace the cracked one and then re bed the others. I am then going to put oversized plexyglass ports over the stock fixed ports. As in this article:
http://www.sailnet.com/forums/gear-maintenance-articles/33774-surface-mounted-ports.html
Double the plexy should keep it from leaking for many years to come. But, first I need to understand the mounting of these stock ports. Any help and thanks.
Discussion Starter · #4 ·
The more I look at how they are put in there. It looks as if they are just held in with adhesive sealant. Am I correct. Can I just push from the inside and get them to pop out? I have to replace two that are cracked already. I just do not understand what the aluminum frame is for on the inside except for cosmetic reasons. What is happening is the water is getting between the top side and the headliner pan andd leaking out in all kinds of places. I recalked today. But, I would much whether rebed and repair. Anyone know how to remove these fixed ports. Thanks
Discussion Starter · #6 ·
great info. I thought that they were just setting in there. I guess the aluminum frame is just to finish off the interior. I think I will fix the two that are cracked and then do another window like you did over the replacement ports. I am truly wanting a leak proof repair. Thanks again
You're best to use plexiglass as opposed to lexan. The plexi will last many times longer than lexan which is destroyed by uv. Plexi also doesn't scratch as easily. All major manufacturers use plexiglass (acrylic) instead of lexan for these reasons. If the cabin side has a recess I would cut the plexi to fit in that recess with a bit of an allowance for expansion and bolt a trim piece to the cabin side with the holes going through the trim and cabin only, not the plexi as that is a future failure point. This way the plexi is floating in sealant - silicone preferred and not stressed at bolt holes. I'm in the same situation as you but don't have the luxury of a cabin side recess. My neighbor's boat was done this way with smoked plexi and other than a few small marks looks original and no leaks - it was built in 1966.
Brian
It isn't that Lexan or Polycarbonate isn't UV-protected, but more that while Lexan or polycarbonate can be treated with a UV coating, the material itself is inherently more subject to UV degradation than acrylic.
I gig not know lexan was not UV protected.
1 - 10 of 10 Posts
