1 - 6 of 6 Posts
hi there all, i am in a bit of sticky situation, i have a old 1972 irwin 38 mk1with aft cockpitt ,this boat i bought 8 months ago and i knew it took on water about 4 gallons a week , this boat is sat in my dock has not moved in 3 months , now its taking on water over the floor every two days , i have looked to see were but all i can see is that its not coming from the rear rather from the middle of the boat , this boat has a swing keel , i thought may be that its something to do with the cable that operates the keel and water is passing though this hole as i said this all started 4 days ago this boat has not moved or hit anything or rained any help would be great ,
Cracked center board trunk?
Close off the seacocks, pump it dry, and look around for the leak or leaks.
· Member
Have you checked the stuffing box where the propeller shaft comes through the hull on the inside and goes to the engine. If that is leaking heavily rather than a drip or two each minute...that could be the issue. Tighten up on the nut there to slow down the leak if that is the case.
Can you haul it out? It would be easier to check the bottom with the boat out of water.
Do you know for certain where all of the through-hulls are? A leak in the cooling water? A siphon?
Discussion Starter · #5 ·
i have found the leak , it was the speed senser in the hull which was mounted in a piece of wood and one time covered in a rubber coating , in short all my attempts to plug this has failed , so the boat will be taken out of the water, thank you to all that replied to my message
1 - 6 of 6 Posts
