Is external rudder a good idea?
1 reading
16K views 56 replies 29 participants last post by  Morild
#1 ·
I have my eyes set on my next new-to-me-boat, but as you can see from the picture it has the rudder mounted on the transom, instead of a more tradtional through-hull rudder.
I don't see that on a lot of bots, and I wonder what are the downsides of this?
I like to think that it easier to inspect and less holes in the boat to worry about, but what am I not seeing? :)
I have attached a picture, I hope, but if that doesn't work here is link to the same picture:
http://sailboatdata.com/imagehelper.asp?file_id=9998
#40 ·
No competent captain would ever venture out in a boat with a transom hung rudder.
Except maybe Columbus, Magellan, Drake, Cook, or Blackbeard. :laugher
IMHO whether you're discussing guitars, cars, cameras, guns, or sailboats, there will be people who over-emphasize one particular feature or design point, and condemn any product that possesses what they consider to be the offending feature.
Show me the boat that can't be criticized in some way. Cats don't point, gasoline powered boats explode, skeg rudders get caught on mermaids, full keel boats won't back up, and trimarans.....look silly.
#42 ·
As far as I can see on a smaller boat like the one in the picture it is neither good nor bad. As a boat get larger and ventures farther offshore, an outboard rudder is a lot more difficult to use as it is a one to one ratio. However, I love outboard rudders for offshore cruising because it is so cheap and easy to build on a reliable windvane that works superlatively, a major plus.
#43 ·
Capta:
I agree with you.
One thing about an outboard rudder is that it gets the head of the tiller out of the cockpit and this can free up cockpit space. It also moves the rudder planform aft and on a small boat this can help with directional stability. On a big boat with wheel steering there are some ways to control the outbpoard rudder but I have never seen one that I thought was not a bit clumsy. You have far more steering options with an inboard rudder.
The outboard rudder on my own 26'er was absolutely perfect.
#46 ·
Capta:
I agree with you.
Bob, right there are the reasons, AIUI, that Joe Adams used an outboard rudder for his highly-successful 'Adams 20' design late last century. That's 66 feet of racing yacht capable of +20 knots hour after hour in strong winds and a Tasman ocean swell.
Not sure I'd call a 66ft boat "small", but it's a relative term I suppose.. ;)
#44 ·
With an inboard rudder you lose the most useful streering option of all, steering via trimtab either for a vane , manual steering, or inside steering. I dont see any options lost with an outboard rudder.
An ex airforce friend mentioned a large cargo plane which was totally controled by trimtabs. At rest, all the control surfaces hung down, and only came to life as the plane started moving. It was so powerful that they had to put in some resistance, as a pilot could easily rip the wings off, without realizing how much force he was putting them under.
#45 · (Edited)
Great Brent. I comforted to know you and I still disagree on just about everything.
You have to move the rudder. When you do you will need something to connect it to the wheel. With an inboard rudder you will have more options in this area.
Maybe not in Swainland but in the rest of the world it works like that. I suggest you take a lok at any Edson Catalog. There are lots of steering arrangement options in the catalog. I know that you would probably prefer welding something of your own design up but lots and lots of sailors use Edson.
#48 ·
Many of Adam's designs did, especially his racers.. but the '20 was the largest of them all.
He seemed to believe that an outboard rudder was best for a racing yacht and an inboard rudder on a cruising yacht. Modern racing yacht design seems to have moved away from that now due to the 'ventilation' issues described by Rich.. but it hasn't necessarily made any difference in winning races.
#49 ·
I eventually took ownership of a Nordship 808 with the external rudder.
After having sailed it during the summer i love it. It responds like a dinghy and allows for easy manuouvering in the habours.
Thanks for great advice.
I have enclosed a picture of the night in June when I took ownership of "Nordild" :)
#56 ·
YES... Number one cause of weather helm is over trimmed sails, Two is an improperly tuned rig.
