1 - 20 of 39 Posts
I was looking at clear non-adhesive silicone sealant today. The "Marine grade" stuff is much more expensive than the "bathroom" grade at Home Depot. Is there a significant enough difference to pay the extra, or is it just a marketing gimmick?
What are you using it for. Silicone-based sealants have very little good use on a boat, other than bedding lexan/acrylic glazing, covering the ends of cotter pins and being used on the bottom of dishware to make it non-skid.
Using it on deck hardware is really a bad idea, since all silicone sealants tend to leave behind contaminants that make resealing the area afterwards almost impossible.
baDumbumbum
Two major kinds of silicone sealants: those with acetic acid (vinegar), and those without. You want the kind without, as the acetic acid can really pit and corrode marine fittings. If you are sure this is a job for silicone (as SD says, it's right for very few boat jobs), use GE Silicone II Sealant, available at your local hardware store. Still about $6 a tube. GE Silicone I is acetic-based, so don't use that.
learning these seemingly small facts is what makes this forum great. I just love picking up these tips! Now I just have think where I may have used the vinegar smelling silicone around the boat!!!! oops!
The problem with the acetic acid-based silicone is that it tends to attack metals... because of the acid. Fortunately, acetic acid isn't all that aggressive an acid.
i have a tube of this stuff on board as my general sealing/adhesive stuff ( also have 4200 ). it a liquid nails product, that is very clear when cured. it sets up pretty quick and is not hard to remove later. if i had to give it a 3m comparison i would say its a little weaker than 4200 but has better flexibility. i used it to seal the plex on my roof hatch, and you have to look to see it. i see it as my 4200 replacement when i dont want the white or want it clear.
What about the hybreds?
This seems like a good thread to ask this... What about those sealants that are half silicon and half something else? It would seem that they have the same issue as silicon (contaminating fiberglass) but many people use lifecaulk and other hybreds.
Spinlock specifically points out in their documentation that polysulphides and urethanes should NOT be used to bed their rope clutches; they want silicone to be used. Reasoning provided is that the polys will degrade the plastic materials? So, I will hope that I never have to rebed.
How do you clean the contaminant residue left behind to get a good seal when rebedding?
Super Moderator
Silicone
You will need to sand it after removing as much as you can by hand. Tape off the areas you don't want sanded and then sand the contaminated area. Certain plastics can have the plasticizers leeched out of them over time from products like polysulfides. This leeching makes the brittle and more prone to failure. In these situations I would recommend Dow 795 as the Silicone of choice..
As Dog stated silicone has very, very few good uses on a boat. Certain plastics require it because they can be attacked by Polysulfides, Polyurethanes or Polyethers.
The problem with Silicone is that it nearly permanently contaminates a surface. Even when you think it is gone and you've rubbed it away it is still there. Simply use a spray bottle, like for ironing, and mist the surface it the water beads the surface is contaminated.
Silicone was and is designed to resist attack by most all chemicals. None of the commercially, body shop strength, removers are really all that safe for fiberglass and even they don't work all that well even on metal.
Once you've used silicone it will be very tough to get anything else will stick to where you had the silicone.
There are also MANY grades of silicone and it goes much deeper than just marine or bath tub. Acrylic hatches should only ever be sealed with Dow 795 or GE SG4000 as these are "structural grade" Silicone products. Bath tub silicone is not even rated as such and should not be used to seal ports or hatches as it is just not safe or prudent behavior.
If you are going to choose a Boat Life product stay away from the combo Life Seal product as you WILL get silicone contamination and choose Life Calk for general bedding uses unless certain plastics like Polycarbonate or Acrylic..
For those of us who have had to atually remove silicone contamination, for paint work, I can asure you the ONLY way to 100% get rid of Silicone contamination of gelcoat is to sand it off.. Just because you can't see it does not mean it is not there, trust me!!
You could always use butyl tape instead. It won't attack plastics to my knowledge and is a very good sealant.
SaltwaterSuzi/CapnLarry
A friend of mine, who spray paints boats for a living absolutely HATES silicon. He says, "The only place silicon belongs on a boat is in the top half of a bikini. And you don't even need the bikini."
That's wrong in so many ways, but so appropriate... :)
...He says, "The only place silicone belongs on a boat is in the top half of a bikini. And you don't even need the bikini."
BTW, it is Silicone, not Silicon, one is used as a sealant, the other in solar panels and micro-chips.
You're right - my bad. I think they use it to make sand, too.
This thread has really helped me. I am in the process of removing the hardware from my Macgregor Venture 17 and have found a ton of silicone. Looks like the installer went nuts with the stuff. I will try what you guys suggested and let you know how it goes.
midlife crisis member
Back to the OP original question, I have used the bathroom variety silicone in an environment that is much harsher than a marine environment. Namely in my bathroom. Around the tub to be specific. It's wet almost all the time (3 teenagers), gets subject to harsh chemicals weekly and has lasted 10 years, and still looks fine.
I am 99% certain that marking the stuff "marine grade" is a marketing ploy designed to fool us into paying 3X the price for the same product.
I am not saying it's appropriate for any particular application, I am saying it's prolly not any better than the hardware store stuff.
Eric
Where can this product be sourced?
Will a reapplication of silicone have the same problem sticking, or is it just other sealants on top of old silicone the problem?
It's mostly paint that will never stick AFAIK. What is the application?
The PO of my boat used silicone to bed the hardware. Since then I have removed all the silicone (with a knife, then sanded whatever residue that was left) and repainted and rebedded with 3M 101 Polysulfide. Time will tell how well the paint sticks and the 3M 101 works.
I will say that the silicone bedded hardware did not leak.
Amazon.com has it. A simple google search would have found it for you.
Pretty much everything has problems sticking to where the silicone was, even new silicone. :)
Hey, you guys gave me an idea. :)
Since 5200 sticks too well, and since silicone leave a residue that prevents other products from sticking well. The solution is simple.
Apply silicone and then remove it from anyplace you want to use 5200. :D
Boy, I'm a genius. :laugher
1 - 20 of 39 Posts
