My 1985 Nauticat 40 Ketch has 2 headstays that are quite close together. I'm wondering if she is designed to be sailed in moderate conditions with both headsails flying, or if she is more in the tradition of a "double headsail rig" whereby you choose one, or the other sail depending on conditions.
The staysail goes from the stem, to the hounds at the upper spreaders. The foresail goes from the bowsprit to the masthead. The slot between these two stays is 2-3 feet only, which makes tacking a genoa quite challenging.
If the boat is designed to be sailed in an either-or configuration I could change the staysail to be removable with a hayfield lever, but the staysail is on a furlex furler, and that seems to be adding complexity.
Does anyone know how she was intended to be sailed?
NAUTICAT 40 sailboat specifications and details on sailboatdata.com
Thanks!
MedSailor
Thanks!
MedSailor
