Hi,
Jabsco macerator pump not pumping just whinning. No whinning please!
We have installed a new VacuFlush toilet and holding tank. All new hoses and hose clamps. We have the hoses coming from the top of the holding tank to the macerator and then to the pump out deck plate which has a O ring. I did tape it closed also so it would not suck air with blue tape. There is not a valve after the macerator. There is a 5\8 vent hose from the tank to outboard. We used the original macerator that was on our 1978 Islander Freeport. There is a valve on the through hole that the macerator pumps to.
We open the valve and the macerator whines just fine. But it never pumps out anything. I tried to rebuild the macerator impeller and housing but the new one ended up freezing up and then when I loosened the housing to pump bolts the impeller disintegrated. My guess is that it was the wrong kit. Any way I put the old impeller and housing back on and tested it in a pale of water and it pumps out water. I did leave the new cutter plate on.Then I reinstalled it. When we go to the pump out station it pumps out fine (not using the macerator). Could I not have the macerator nots tight enough? There are four nuts holding the pump parts to the motor. I have tried different tightening amounts. The tank I am trying to pump out is 31 gal and the tank is half full. I have checked the through valve the macerator pumps out to and it is clear to outside the boat. There are not any obstruction in the housing.
Could the macerator be leaking in air where the impeller housing connects to the electric pump?
The deck plate has an O ring which I replaced but am nut sure if it is the original size. I taped it shut. Would I still need a valve after the macerator to deck plate? The people who sold us the toilet said no.
Why would the macerator not pump out from the holding tank?
Thanks,
Chip
Thanks,
Chip
