Hi.
I just bought an older 4hp Johnson, and it seems in good shape. Starts and runs fine, but there is only a dribble coming out of the 4 vertical holes in the middle of the leg. I'm assuming these are the exit holes for the water pump, but maybe I'm wrong?? I did change the impeller even though the old one looked fine thinking that would fix it, but no luck, even at high RPM.
Anyone have any experience with this motor, and know what I should expect as far as flow thru the pump?
Thanks for any help!
