1 - 3 of 3 Posts
what year? try a clymer or helmes service manual. you can also try some parts advisers online. they have exploded views that may help you. most likely it will be 2 to 4 bolts to drop the lower unit. then you have to pull the old impeller and install a new one. thats the quick of it as it involves draining the lower unit oil, possibly some impeller install lube, etc...
1 - 3 of 3 Posts
