Ok, so after some extensive searching, I've found the keel bolt repair thread. It seems that a sistering application may be the most appropriate avenue. Can anyone tell me which category the T30 falls into? Stub for keel attachment or reinforcing grid in the bilge from the reference below?
Whether sistering is applicable depends on how your hull is reinforced to take the strain of the bolts. A hull with a stub for the keel to attach to is likely to have ample strong locations for additional bolts, whereas a boat constructed with a reinforcing grid in the bilge may provide fewer strong positions. If your bilge exhibits space for more bolts-perhaps enhanced with some additional reinforcement-their installation is relatively straightforward.
Typically, to replace the keel bolts, when they are cast, it takes a special pipe bit to over bore the bolts. Then you have to reset and pour new lead to seat them. The same procedure would have to be done for sistering the bolts as most keel bolts have the bottom couple of inches bent at 90* to keep them from pulling out. The keel would have to be dropped, similar to the method shown in my "keel" thread. http://www.sailnet.com/forums/gear-...-those-contemplating-procedure-your-boat.html
1 - 4 of 4 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
A forum community dedicated to Sailing enthusiasts. Come join the discussion about sailing, modifications, classifieds, troubleshooting, repairs, reviews, maintenance, and more!
