1 - 5 of 5 Posts
I have a 40 ft gaffrigged motor sailer, a converted fishing boat built in 1934 with a full keel ,
is it possible to extend the keel downward and bolt ballast to this instead of having 1.5 tonnes under the floorboards
will this extra draught affect the handling , and/or reduce sideslip
[currently looking at extending dowm 250mm, full length ]
· Once known as Hartley18
It's certainly possible to do this - but not without some really good advice from a qualified Naval Architect first. If the boat isn't designed to carry the weight down there, you could really stuff up your day...
If the boat is that old, it's probably a one-off. Try to locate the designer/design house and ask them. If not, call a surveyor.
· Telstar 28
I'd second getting a naval architect to look at it.. and go over how the new ballast would be attached.
· Super Moderator
If your boat is a 1934 motorsailor and you want to head upwind and not have too much leeway, starting the engine will probably be a lot cheaper and easier than deepening your keel by 25 cm by adding a shoe of some type to the keel. Adding that much wetted surface would likely slow down the boat a lot (perhaps by 2-or more knots?), to say nothing of the ability of the now elderly structure to support the weight and stresses involved. If you're not happy with the boat you have, perhaps you need a different boat. That's what the changes you're talking about seem to indicate.
1 - 5 of 5 Posts
