1 - 3 of 3 Posts
Discussion Starter #1 (Edited)
Hello -
I recently purchased a Windrose 25' and I am attaching the boom to the mast. However, there appears to be two shaved off bolts in the mast. I'm not sure what was once there. You can see two shaved off bolts in the attached picture.
Anyone have any information on what was probably once there? How, I should properly attach the boom to the mast?
thanks
-h
Don't see the shaved off bolts. If there is one at the bottom of the slot where the boom is fitted it could have been there as a stop to keep the slot gooseneck fitting from dropping out of the channel and, if there is one above, to keep the boom from being hoisted too high.
1 - 3 of 3 Posts
