Lazy Jacks, Love'em or leave'em?
  • Have them and love'em
    Votes: 35 54.7%
  • Have them and wish I didn't
    Votes: 5 7.8%
  • Don't have them; don't want them
    Votes: 9 14.1%
  • Don't have them; wish I did
    Votes: 15 23.4%
1 - 20 of 45 Posts
Wandering Aimlessly
I have them primarily because I singlehand.
One of None
Hunter 34
I only love em when dropping the main.
Maybe you should have the question
"do you love and hate your lazy jacks?"
On a busy river with a shipping channel like where I'm at, just the time it takes to drop the main without jacks can be dangerous for the singlehander!
Glad I found Sailnet
I have then and love them. Although our 50 have a "tradewids mast" that is shorter than the taller version, I find the main to be rather large. Having lazy jacks makes it easy to lower the large main. (And with just one zipper I have the main covered and away from the sun.) Being easier also means I'm more likely to take her out for a short sail. Finally, whether I single hand (not yet, boat is still pretty new-to-me) or not, one person can secure the main, quite easily.
The only downside is you really have to be pointing into the wind when raising the main, or else our battens catch on the lazy jacks. This is not really a problem when there's another crew member on board to turn her up at the right moment, when starting from a mooring, or when using the autopilot and engine to hold her into the wind. (I'll have to experiment with doing this single handed.)
Bottom line, love our lazy jacks.
Se帽or Member
I've got 'em, and overall I'm happy with them. That said, there are a few things that kind of stick in my craw.
I've got a new mainsail, which has yet to soften up enough to flake easily into the bag. Therefore, I've got to stuff, poke, and wrestle with it to get it in far enough so the zipper of the bag can be closed.
Secondly (and this is more a rigging issue than a Jack design problem) my reefing lines ALWAYS fall outside of the bag, and so I've got to manually stuff these into the bag before it can be closed.
But, all things considered, I'm happy enough that I aint gonna be taking the Jacks off to replace them with something else.
The real key to loving them is making them collapsible so when raising the main you can pull them forward so battens etc hanging up is a non issue. Have sailed on boats without this set-up and not near as easy as ours. When dropping just pull them back out and away you go. It also means you don't have as many slots in the sailcover.
I sail a lot of different boats. Many have lazy jacks. A system set up as above is a dream. Those that cannot be stowed forward can be a nightmare.
Jack
Midwest Puddle Pirate
I have the lazy cradle system from Sailcare. Basically it's a set of lazyjacks with the lower section made of elastic. I deploy them before dropping the main, and stow them as I put the sail cover on. They're never in the way because they stay at the mast until I need them.
Ours are removable, set up on shock cords off the rig except when dousing the main. This gets away from most of the hassle during raising the main and also allows use of a conventional mainsail cover.
We primarily use them to prevent the main from dropping all over the dodger and scratching the ($$$) lexan windows.
Chesapeake Sailor
We use the Dutchman and have had pretty good results with it as a replacement for lazy jacks that we used on other boats. Both work reasonably well. The Dutchman requires pretty precise set-up and adjustment, but when done correctly, it is really convenient.
Wayne
1 - 20 of 45 Posts
