1 - 5 of 5 Posts
Super Moderator
Farr 11.6 (Farr 38)
Yes there are differences...the Lewmars are a little smoother acting and seemingly lower friction. Lewmars are available with an aluminum drum configuration and so can be significantly lighter in weight. Lewmars have better spare part availability. If you are in a high salt environment then the chrome on bronze or stainless steel Lewmar or stainless steel Anderson may be a slightly better option. In either case, its the maintenance cycle that makes the biggest difference.
Anderson 40st all stainless weight 5 kg, Lewmar 40st weighs 4.9 kg in aluminum (3.52 ounces lighter) and upto 6.7 kg in stainless or bronze. Anderson is probably the most durable winch available and very easy to service. Anderson recommends 2 yr service interval as opposed to most others which are i yr. So the weight is very close but the price might not be. I own 2 Anderson 40st and two 28st and couldn't be happier.
Brian
1 - 5 of 5 Posts
