1 - 4 of 4 Posts
When new, my Lewmar XAS clutch opens and closes easily even unload. Now it takes some effort. I wanted to strip it to service. I unscrew the 3 bolts and nuts on the side but cannot split open the clutches. Any advise appreciated.
Umm... Lewmar doesn't make the XAS clutch. Spinlock does. Be aware that Spinlock clutches often have a problem releasing if under a heavy load. That's one reason I don't like them and don't recommend them.
Hinterhoeller HR28
You can remove the cam in the Spinlock XAS without disassembly. Clean everything, and maybe a shot of McLube Sailkote on the lever pivot (NOT on the friction surfaces!)
Discussion Starter · #4 ·
Ok must be the sun that's clouding my sight, its Spinlock XAS. Thanks. I sparyed it with McLube, helped some but not to what I expect. Any idea how the cam can be removed without disassembly? Shouild I knock out the 1 large pin that holds all 3 cam lever ?
1 - 4 of 4 Posts
