1 - 11 of 11 Posts
After a recent lifeline issue, this afternoon I replaced my upper lifelines. I removed the lowers, should I bother replacing or just stay with uppers only?
I have been coughs by the lowers a couple of times racing in heavy weather.
I you know that you want fall and slide on a sloping deck - just don't bother to install.
But if you ca avoid one mob situation is worth the money in my book.
Yes, you want lowers. Pretty common to go scooting under. Doubles your chances of catching hold of something. Holds the sails on deck better too.
I look around the marina, and probably 80% of boats only have an upper. I expect I'll end up fitting a lower anyway.
This is one of those times when the 80% is wrong. Toe rails too. It is sliding that I would worry about.
Remember you're a womble
Discussion Starter · #11 ·
I mostly singlehand, coastal/inshore in fairly protected waters, and daysailing I get the choice of going out in snorty weather or not. Anyway, I have made and fitted a new set of lifelines, uppers and lowers, in fancy high-tech line. That 12 strand stuff is so easy to splice.
1 - 11 of 11 Posts
