Actually a truck diesel isn't broken in until about 40000 miles, or 1000 hrs, break in time. Truck engines if maintained well, will run over a million miles before needing major rebuilds. At least the old 1s I drove did. That would be 60s, 70s, 80s, and to mid 90s. Todays engines run better, and hotter, because of computers, but are built lighter for weight savings, ie better fuel economy. Also there is a lot of plastic, and aluminum on them. the engines hours should not dictate when it is time for a rebuild/repair. That is or should be dictated by the maintenance it has received, and or any issues that crop up during use, and how fast you can react to the problem, before you do damage!!!!!!
