Question for you guys, on the bottom of our boat we have a steal plate about the size of a index card that looks to be used for grounding of the mast. There is a larger wire coming from the mast to this plate and one wire going to a keel bolt. what is the best way to do this just to the keel or to this plate as well. also are there other things that should be hooked to the ground at this plate or keel bolts like the engine or better systems? thanks
Scott
Scott
