The album of Ariel #422 - Page 14 - Pearson Ariel Association Forums
Towards the bottom of the page shows the result of a lightning strike.
Some masts are heat treated, most are 'soft' with the sole treatment being a controlled cooling fom the extrusion process. Would be good to find out what type you have before making a good guess.
sounds as though the lightning took the wiring down instead of the mast, so odds are good that the mast is fine. Look for discoloration.
As for possible fiberglass damage as shown in the link, your nose is your freind because singed fiberglass has a distinct smell that's different from plain 'old' fiberglass.
The lightning had to go somewhere, so be sure to check around the through hulls and anywhere that there is metal close to the hull. Damage to fiberglass is normally from the resin burning and leaving just the glass so you can often feel a soft spot.
Ken.
Ken.
