1 - 20 of 348 Posts
Discussion Starter #1
hi. I just bought a 1971 cal 27. it's the original cal ( with the pop top ), not a 2-27, 3-27, or T2. it's in need of a little work. i'm finding little detailed info, on line, and I was hoping a few things could be made a bit clearer if I could speak with people who own or have owned one of these boats. below is a picture of the boat I just bought, for ID purposes. thanks.
Hi Captain Jack. My name is Michael and I currently own a 1970 Cal 27 with the Pop Top. I gotta tell you. I absolutely love that pop top! I'm currently working on engineering a lift support system to assist in getting that thing up and down. LOL I have posted some pictures of 'Starship Del Rocio' on my page. I have a TON of documentation. Please let me know what I can help with. :)
Michael
Discussion Starter #4
really? that's funny. I have a number of questions about the boat. mine needs a little work. the woodwork, inside looks good, but the door to the berth is missing. the cushions are all missing. it needs paint, inside, and over all cleaning.
one question I have is about the head. did these boats have a marine head or a portable head? there isn't a head, in the boat, right now. there is a tank under the cockpit sole that I think may be for the head, but i'm not sure.
also, this is probable a dumb question but, there is a handle to starboard, right on the cockpit bench....well, the side of it. it's a crank, like a large window winder. I have a suspicion that it's a manual bilge pump, but i'm not sure and I can't really test it. the bilge is bone dry. can you tell me what it is?
one last thing, for now, I haven't checked to see your pics yet, but it would be really great to see some pictures of the interior, so I can see what isn't right on mine.
it's good to meet you. I can't believe how hard it is to find detailed info about some boats and yet it's a breeze on others. if this was a 2-27, there's tons of info.
thanks for responding.
oh. one other thing, how's she sail?
Discussion Starter #5 (Edited)
I just looked at your boat 'picture' and I'm shocked to discover its almost identical!! lol
it's a dark picture. it does make it look like yours, though. actually, it is white with a blue stripe. at about the aft most pat of the cabin, there is a 3 or 4 foot wide blue stripe, angling backwards, that goes down to the waterline. you can't see the wide stripe because there is a finger dock in the way. I posted about this boat under the general forum, in a thread called " I found a better boat ".
Ok - Lets take this one at a time. First ~ Congrats on acquiring a pronominal boat. These boats are sturdy, quick, a safe cruisers. I absolutely love mine. With that said, lets start.
1. The door to the birth is a two part door separating in the middle. You should be able to locate the track as they are right on the wall where the bed begin right by the vbirth cousins. These doors slide in opposite directions to open and close. I'd be happy to take pics and measurements as you require to help you along.
2. The head is a portable head with access to external plumbing to extract waste if desired. I simply use mine as a port-a-potty. Emergency
/lady use only. lol I can send you pics and have documentation that came with boat. I'd be happy to copy and email if you like.
3. The handle to starboard, right on the cockpit bench is actually the lever (white ball on end of handle) for the transmission on my boat; forward (all the way forward), neutral (middle), and revers (pulled all the way aft). I have documentation on this as well. I have a dry bilge as well and there is a whale pump in the cabin located on the bench wall on the starboard side.
4. I don't have any pics of the interior, but I will take some for you and post them.
I hope this helps.
Its nice to meet you as well and look forward to learning more about your boat.
Question: Your boat is a 1971 correct? Mine is a 1970 (1st design) My hull number is 101 (Very first design of CAL to have an inboard motor.
What type of engine does your have?
Thanks again and nice to meet you.
Michael
Discussion Starter #8
it's good to know they are a good sailing boat. I will be sailing on the Chesapeake and it can get rough, sometimes.
I did see the track. I didn't realize it was a split door, though. I thought it as a single panel. I don't need measurements, though. if you are going to take interior picks for me to look at, that will be good enough.
really? that would be great. my email is [email protected]. thanks. that would be a big help. so, what do you think about the tank under the cockpit sole? is there one on your boat?
I don't have a transmission. it's set up for an outboard, not an inboard. but that does sound like the handle. when you say a whale pump, I assume you mean for the bilge?
thanks. I appreciate that. it'd be a huge help.
I hope this helps.
Michael
yes. it is a '71. I didn't know that about it being cal's first inboard. that was an option, though. one that the original owner of my boat didn't opt for. thanks for your help. it's good to know i'm not alone out there. lol. I don't know my hull number. I couldn't find the HIN. the title just has a 4 digit number there. it's 107-something. maybe 107-9. I can't remember. I will have to look.
thanks again
Discussion Starter #9
Oh - The tank directly under the cockpit is a fuel cell for the inboard engine.
oh. that answers that. my boat has no inboard, though. I wonder if they just set them all up in case they got an inboard.
Your hull number should be in the glass somewhere. I will locate mine and tell you where I found it. It took a closer look at your original pictures and seems as though your boat was ORIGINALLY shipped with an engine. Probably a VIRE 7 / 1 lunger 2 stroke. You will notice on the floor in the **** pit just in front of the hatch, you will notice a cover with 'FUEL' on it. That lever with the white handle operated the transmission which was attached to the VIRE 7. It's obviously gone now. If the boat was shipped without an inboard engine, the transmission gear selector and fuel cell would never have been installed. Additionally, if that boat wasn't shipped with a inboard, the transom would have been cut to accommodate for an outboard engine. If you look carefully at the transom on the inside, you can actually see the outline where the cut would be. I have seen of few of these CAL's with the outboard option.
NOTE: There are TWO sets doors! One that separates the main cabin from the bathroom (one piece door sliding from starboard to port), and that second set of doors we already talked about. This set up allowed the head to be completely isolated from vbirth and main cabin if desired. Hope that made sense and you may already know this.
Discussion Starter #12
ok. that's interesting. I have seen pictures of a cal 27 with just such a cut out. I had wondered about that cut out when I saw the pictures. so, if the engine had been removed, do you think they glassed over the place where the shaft exited the hull? perhaps the actual shaft and propeller are still there. I haven't seen the underside because I am not hauling her til it's time to scrape barnacles and do the bottom paint.
depending on whether the shaft is still in place or not, how hard to you think it'd be to put another motor in it? would it even be worth it? perhaps I could remove the fuel cell and put a holding tank there, for the head, or convert the fuel cell to a holding tank. I really would like am actual marine head, instead of a portable head. I was considering a composting head, as well.
Good to see this dialogue.. thanks for helping out, Michael.
Jack you should be able to see if the original prop shaft is in place, it should be visible from inside (I would think) just ahead of the tank. If someone's converted the original inboard engine space to storage it may be buried there. It's also possible someone removed it and glassed it over. If you stick to your electric power/engineless plan you obviously won't need the tank, that will open up more storage when you take it out. Not sure about converting to a holding tank, it would need some modification and large diameter hoses attached somehow..
If all the parts are there it likely is possible to repower with another inboard but probably not worth the cost. Possibly even an electric drive, but again $$$$$.
But it's great to have a resource like Michael.
Discussion Starter #14
it most definitely is!
I am going by the boat, today, before I go to teach class. I figured i'd get in some work. I will look, when I am there. thanks for the input. i just never considered that it originally may have had an inboard.
Discussion Starter #15
no. actually, i didn't know that. i was talking about the door that separates the cabin from the head/berth. i hadn't realized you could close the head off from the berth, too. that's cool. you, my friend, are a wealth of information. thank you so much.
Engine: I would definetely look at a different solution for the engine. As you may or may not know, that boat weighs at LEAST 5400 pounds without any souls on board. I find my original engine underpowered and I will be looking to switch it out with a 2 GM of some type. I will be looking to glass in a 25 hp for more to help with the 20 ft swells we can get in the bath tub they call Lake Michigan. Also, I like coming in hot and exercising the sphincters of the old guys that like to wait on the dock ready to catch mooring lines. LOL I see it as a public service. lol I'll be by the boat and I will take pictures and a video for you Captain Jack.
What I have found is boaters, sailor and power alike, are among the friendliest of people I have ever met. I am merely repaying the kindness others have shown me and continue to do so. Anything I can do to help. :)
Bathroom: It will take considerable effort and resources to convert that fuel cell to a holding tank. Waste will need to be pumped a long way back and up into that tank and what a mess you will have if, after a night of celebration, someone tries to flush a dead beaver through. Ugh.. Don't laugh.. been there, done that! LOL Additionally, a solution will be needed for pump out from that location. If a holding tank for the potty is really set deep and true into your desires, I would look at what you can fabricate and install BELOW the head. That way you can utilize gravity and some existing help that came with the boat. IE: Pump out features that were build into the boat. :)
I would take everything the marine owner will give you. You can use the sailing paraphernalia you don't use to barter for things you may need. Your boat can accommodate a smaller jib in addition to the main job. You will see the ring on the mast just under the steaming light and you will see the track directly on the deck towards the bow. For the jib, look for a 120 but no more than a 180. We'll talk more about sails later. But, I wanted you to know as you go through the sails available.
Discussion Starter #20
so, do you think that a 9.9 outboard would be a good choice? I only want it for emergencies: no wind and I just have to get back or sails shredded, mast broken, and I can't sail sort of thing. possibly for moving into or out of the slip in contrary winds. not looking to hot dog it, but I need to be able to move the boat, too.
thanks for being willing to take picks for me. I can't tell you how big a help that will be; like a lighthouse on a foggy night.
1 - 20 of 348 Posts
