What do you use to lube your gear cable?
And your throttle cable?
Thanks.
Thanks.
Ain't it the truth! I spent the better part of a Saturday trying to lube my throttle cable using the method described in Casey's "Sailboat Maintenance". It did help, but it still wasn't right. Ponied up for a new cable (not cheap, the motor is midships, so it's a 20' cable). Man...what a difference!You can try and get almost any type of oil in one of the ends (preferably) the high end so it can run downhill
BUT the cables have a plastic lining that is one of those lifetime deals and the lifetime may have passed![]()
