1 - 9 of 9 Posts
What is the recommended lubricant for turnbuckles?
So far I have a list including:
dry molybdenum
white teflon grease
anhydrous lanolin
Any insight into the pros/cons of the above (or other options) would be appreciated along with possible sources of these lubes.
Any of those should work fairly well. The main issue with turnbuckles, especially stainless steel ones, is galling and seizing.
Seen Your Mamba
dry molybdenum
white teflon grease
anhydrous lanolin
I use Lanacote. It's cheap, works well, and I've barely scratched the surface of the 4 ounce jar I bought for $10 or so (8 x 1/4" turnbuckles).
The only thing I don't like about it is that early/late in the season it hardens up and makes turning the turnbuckles by hand harder than in the heat of the summer (at least here in Niagara - you'd probably find the same thing in Ottawa).
If it isn't anhydrous lanolin, don't use it on a boat. Normal lanolin will probably cause more problems than it solves.
I got a tube of lanolin at Target. It's in the baby section (for mom's who are nursing).
I would hesitate to use dry graphite lubricant on a boat. Graphite is very high on the anodic scale, and as such can cause galvanic corrosion if it is in close contact to bronze, stainless steel or aluminum and salt water. :)
Any kind of grease like Lanacote or a Teflon grease works well. I don't see any advantages to using a dry lube. Especially on closed body turnbuckles. You want something that stays greasy and you want to be sure to exercise the turnbuckles once in a while.
1 - 9 of 9 Posts
