M 5424 diesel 3 cyl for sale
7899 Views 10 Replies 7 Participants Last post by  jimmys37
#1 (permalink) 2 Hours Ago - [add post to favorites]
jefframage
Junior Member Join Date: Sep 2009
M5424 well running engine available
repowering. remodeling, rewiring my 1978 S2. Items available:
3 cyl Universal diesel Kubota based engine, fuel tank, transmission, tub, toilet, cabinet, all associated fittings available, power panel
Universal 5424 3 cylinder diesel for sale. was originally in S2 11.0 Center cockpit. Repowered my 9.2 meter center cockpit with it as a temporary repower. Moving forward with new repower now.
Well running, 5424 Universal diesel for sale or for parts.
Original in 36 foot S2 sailboat. Used last 5 years in 30' S2 Sailboat. Pushes boat at over 8 knots. no smoke, no oil, no white, good from cold start, no starting fluid, fires right up.
Fresh water use mostly, Cheasapeake Bay, and Great Lakes.
Closed loop cooling only.
Engine still in boat. I will remove
Great for cost effective repower.
I will crate, you pay for shipping pick up either from Northern Michigan or Cincinnati. Weight 385#s.
transmission available as well.
18 gallon original aluminum 18" tall diesel tank for sale.
head fittings - tub, toilet, cabinet, etc also for sale.
rebuilding, repowering, remodeling.
See less See more
1 - 11 of 11 Posts
Interested in you engine
Hey Jeff, I need an engine for my '79 S2 11.0. Is the trans a V-drive? What year and approximate hours?
Thanks, Dan
Hey - Motor came out of an S2 11 meter 1981
I don't know if it connected to a V or Sail drive.
the 9.2 C that I installed it in has a straight shaft out the back.
It is either a Hurst or ZF transmission, and I think it is the ZF.
Hours I don't know. I've put a hundred or so on it since I installed.
Hello ' Is the unit still available ? Thank you Gregg
Yep, still available, not yet pulled out of my boat.
Diesel
Jeff,
How much are you asking? I can not PM you I do not have enough posts, perhaps you can PM me?
Nelson
Contact info
Jeff,
You can email me directly at nelsonstruck at yahoo dot com
engine
Is the engine still available???
jjack57
@gmail.com
Universal 5424
Where are you located? Contact Tel. #
jefframage
What is the price? with xmission? where are you located? Contact Tel. #
Jack
Hello Jeff,
Might you have the Fuel Injection Pump (w. the agrivator arm) available for sale?
Thanks... Thyme 305 896-7376
Please call Jim at 502-365-6141 to better describe the Universal Engine.
Thanks
1 - 11 of 11 Posts
