1 - 16 of 16 Posts
Our 28' Alerion Express has a ~40' mast, fixed keel and was initially rigged with portable davit at the boat ramp. When sailing last week the main sail came down (failed shackle or install error) leaving the halyard at the top of the mast. Thought about using a chair lift but the jib is on a roller furling so that was going to be a lot of work and being fractional rigged reaching the top of the mast was still going to be challenge. No ladder telephone poles were at the ramp and the marina never called back about allowing us to walk on top of their travel lift so I could reach out for the dangeling halyard end via pole hook. I slept on problem and dreamed about a way to get to the halyard without climbing or de-rigging. The rear (stern/aft) stay just happened to go to the top of the mast and was attached to a bracket protruding about 8-10" towards the rear of the boat. I stopped at the big-box store for cheap PVC (.79ea) and couplings (1.59ea). I slit 6 - 8' by 1/2" PVC pipes to the end except one and a half dozen coupling's length wise. I started with a four foot length of PVC (easier to get started up the stay while standing on the stern of the boat) and attached a 45 degree fitting, the end of this four foot length was not slit all the way by a couple of inches, so the rear stay cable does not go all the way through this one length of PVC. Attached a six to eight inch length of unslit PVC on the other end of the 45 degree coupling. I fashioned a hook from a metal coat hanger (getting harded to find) and installed it into the 6-8" PVC piece securing with duct tape. I then slid a total of 4 slit 8' pipes up the rear stay attaching each to another with the slit couplers. I duct taped each fitting snuggly in place (both horizontally and vertically) as I advanced the contraption up the stay eight feet at a time. I then twisted the whole assembly until I snagged the halyard with the hanger hook. With the halyard snagged (yea!!!) I slowly un-assembled the PVC a length at a time to get it all apart and down along with the halyard. :) Cost ~$20 for pipe and couplings (threw away after use), plus duct tape, hack saw and/or PVC cutting tool.
Short impromtu YouTube video to watch. You will see that I grabbed it, started to bring it down but it jumped off our coat hanger hook. It took a couple of more grabs of the rope at the top and it finally came all the way down!!! Yay!!!!
Share Add to
Learning the HARD way...
Excellent idea! This should be posted to Low Buck Projects thread.
Welcome to Sailnet!!
Wow, that's impressive. Same thing happened to me a few years ago but the rig on the boat was old and I didn't trust going up the mast tethered to the jib halyard.
So I first motored over to nearby pier that had a building with a second story on it. I got off the boat and walked the jib halyard up to the deck on the second story of the building so I was parallel to the top of the mast (24' boat at the time) and tried to pull the mast to me. Try as I might - pulling and rocking the boat - I couldn't get it near close enough to grab the halyard. Which made me even more impressed by that old wind power which heels the boat with ease.
Anyway, I eventually bit the bullet and motored the boat to my yard. The yard guys put an employee on the fork end of a big fork lift and raised him as high as it would go and moved it as close as they could to my boat in the water. I could barely watch as the guy leaned out off of the end of the fork and grabbed my halyard.
Cost me $100.
You are much smarter then I.
Good Idea/
I taped 5 dockmates boathooks together with duct tape.
Irrationally Exuberant
short movie taken via I-Phone, on brothers phone, have to get it off and then learn how to post it on sailnet.com ..... coming asap.....:)
One way would be to upload the video on Youtube and then link to it in a post.
LOL, this is awesome. I just replaced some running rigging the other day. I made absolutely sure to hang on to the loose ends, while unhooking the shackles, etc. Very afraid of heights and was sure I was going to "lose my grip on something" and have to go up the stick.
I'll tuck this idea in the "hope I never need it, but if I do . . . " category.
Would love to see a pic or video too.
~markb
That's my way of doing things. duct tape and 8' poles. And I'm tying messenger lines to all my halyards.
And My halyards have a little loop on the pull...Now I know what it is for. :headsmack:
what do you use as a messenger line and how to do you secure it to your halyards... mine are getting old enough that I'm thinking I should pre rig them that way, no obvious chafe yet but want to be prepared.
Was the loop on the pull of the halyard (I assume you mean the end that terminates in the cockpit?) done by you? How (if you know, if you didn't do it)? - sounds like a good idea.
Thanks,
Jon
Good Idea/
I would have to use the chef's method...I don't have a backstay! Your idea is genius however! Thanks for sharing.
Discussion Starter · #16 ·
I did it! Video posted. Boy, there is a first time for everything. First getting the halyard stuck, getting it down and now posting a video on YouTube. Thanks again for the coaching. :D
1 - 16 of 16 Posts
