1 - 20 of 39 Posts
Hi,
I see a lot of boats carrying MOB markers onboard. So,e easily accessible and ready to deploy and some secured on deck etc.
has anyone used it and whether it is worthwhile having it onboard?
Any comments welcome
petar
Hi Petar,
i have used them for practice only. Most off shore boats carry them. It is easier to see the flag flying 5 ft above the water then to see some ones head and arms waving. I believe a strobe light is also attached to them for night time use.
I single hand 99% of the time so it would'nt do me much good to have one?
The problem with many is that their design doesn't let them be deployed quickly enough to be really helpful.
I attatched a strobe to the top of mine. It also sat in a pieve of pvc next to the tiller. The pvc strapped to the stern pulpit. The pole was attatched to the bouy ring by about 3 foot of line. It was tied to the stern pulpit also with three slip knots. It was a very simple release......i2f
I don't sail at sea, so don't have, nor have ever used one. However, when I was in the Navy, we frequently conducted man overboard drills and also from time to time, made personnel transfers between ships using a 26 ft. motorboat. In open sea (not storm conditions), there are frequently significant swells. Sometimes, that motorboat would drop completely out of sight from the second level on the ship as it motored across the water. In the man overboard drills, keeping sight of the man (dummy) was difficult. Add swells or significant waves, and you could loose sight of the man. The man overboard poles have the red/yellow flag suspended above the water, and would, it seems to me, be much easier to spot than a person in the water with only his head sticking above the surface.
the boats I have sailed on are set up like i2f's. It is my understanding that both mob and vessel meet at the pole. Horse shoe ring is for flotation and retrieval of mob. In theory. we always use jack lines and strap in as well.
In heavier seas and wind, it isn't always possible for the MOB to meet the boat... the boat usually has to go to him/her. The purpose of an MOB pole is to mark the location of the MOB... and if you can't deploy it quickly enough, it is pretty useless.
Bristol 45.5 - AiniA
Adding a drogue and whistle
I think it is important to have a drogue attached to the MOB and life ring combo since otherwise it can drift faster than a person could swim to it. I have a MOB pole, whistle, light and drogue connected by 50 feet of floating line. It is set up along the lower lifeline aft of the gate (center cockpit boat) and can be released quite quickly. Without a SSB antenna in the backstay the pole can handily mounted along the backstay. I also have a LifeSling and tackle for bringing someone back aboard.
My question in all this is what is the priority if someone goes over: getting the MOB out, hitting the MOB button GPS/plotter or getting the boat at least slowed down. To me it makes sense to hit the button, get the pole out and then get stopped and turned around but I am open to counter arguments.
I agree with you and the only thing I would add, is if you have the crew, is to get a spotter and his eyes on your man over board.
the pointy end is the bow
That's the setup we have. The horseshoe buoy with a little drogue collar sits in a bracket behind the MOB pole. Pull a pin, the pole drops over board, which is attached to a line to the horseshoe buoy. The whole thing goes over in 15 seconds. Hope it never gets used. A strobe is a great idea to go along with it.
I borrowed a good idea from a friend. The pole sits in a PVC tube (pretty standard, I reckon), the flag at the top is flaked onto the pole and a fabric sleeve is pulled down over it. The end of the sleeve has a light piece of line connected to the backstay.
I've seen so many boats with a faded tattered flag fluttering off the top of the MOB pole, this solution keeps the flag in good shape and deploys it automatically, the sleeve stays behind still tied to the backstay.
I now use this on my own boat.
You stop and turn around? I'd rather keep moving...
Anyway I have seen these things on other boats but don't have one of my own. Five foot waves are not unusual in our waters and such a thing would probably help. However, despite some of the descriptions in this thread I really can't picture the deployment. It is stowed in a PVC tube you say? Is this tube attached to the pushput? Does it contain the entire pole, or just the bottom or middle? Do you have to pull the pole out of its tube or is there some clever quick-release thingy?
i2f's setup sounds smart, but it's not clear to me whether it's a two-step (throw ring, throw pole) or one-step process (throw ring, pole gets pulled out automatically).
Grasshopper
Usually only the top of the pole with the flag fits folded up inside a short tube (maybe 6" long), generally fitted to a back stay higher up, and the bottom of the tube sits on a simple bracket mounted to a hand rail or cap rail. In this installation, the pole would be laying parallel with the back stay. A length of floating line is attached to both the pole and a horse shoe life ring, and the life ring is generally also mounted on a simple hanger on a hand rail. In an installation like this both the pole and the life ring would have to be thrown at the same time, or as close to the same time as possible.
Adam, if you have a split backstay, installing the pole becomes a bit harder. But for a single backstay...you can either have the pole sitting in a "cup" (i.e. a piece of PVC pipe a foot tall) and the top end inserted in another piece of pipe with no top on it. Then all you need to do is lift the pole up out of the cup, and pull it back down (out of the top) letting it fall past the transom.
The idea is that the "cup" on the bottom holds it securely enough to keep it in place even when you are bouncing around or take water over the transom.
The other way to do this is to just use a top cover (which keeps the flag stowed) and let the bottom end of the pole just hang in space, free to fall. And, you add one fastpin somewhere in the middle, to pin the pole to a mount on the backstay or pushpit. Pull the pin, and the pole falls down all by itself. Very very slightly faster deployment.
Some boats (purpose built racers usually) have kept the poles stowed in an "aft torpedo tube", which is nice if you're having the transom refinished. You cut a 4"-6" hole in the transom, install a long PVC pipe inside, secure it all and finish it off. Then the pole is stowed inside the tube and pulled out by a leash, when and if needed. No windage aloft, out of sight out of mind, but a way more expensive project.<G>
If you only will need the pole once in a while, you can always just lash it to the rail with some slip knots or rubber bands, and cut or break them if you need to deploy it. Cutting is easy, you DO always have a small sharp knife on your belt, right?
Bombay Explorer 44
As well as the MOB device I was told to throw things that float like seatcushions etc.
One person should be the designated spotter whose job it is to point at the person in the water and to NEVER take their eyes off them.
Worked for us on a transatlantic when someone [against standing orders] jumped overboard to rescue a cat overboard.
We got everything back. The cat was first with a leap from 4 feet away!
PO did this on my boat even though it has a split backstay. He just angled the cup to match the angle of the stay; it holds up just fine. To deploy, just pull the base out of the cup, and let it drop in the wake. Never had to use it in anger, but I've tested it and it works fine.
Hi,
This works well, and is mandatory in some ocean races. Bit much, though :)
It sits in a SS bracket on my boat and also has a floating light attached to a long lead of its own.
The arrangement has an amusing side effect: the light must be tethered upside down so as not to activate the batteries. In choppy sea, the transom will give it a kick every time it rises, so we have an unintended "rough sea strobe". When it begins to flash with the waves, we know things are reasonably rough :)
1 - 20 of 39 Posts
