So instead of re painting my entire mast, I could strip all paint, buff it and leave it as is? Where fitting contact the mast, I would use proper isolation between mast and fitting to reduce corrosion.
So instead of re painting my entire mast, I could strip all paint, buff it and leave it as is? Where fitting contact the mast, I would use proper isolation between mast and fitting to reduce corrosion.The inside of the mast is open to the air. Water, salt, and air are okay. The surfaces under fittings don't get enough air. Good primer, paint and some sealants keep the water and salt away while reducing electrolysis from the different metals.
Alloy aluminum used in masts is quite resistant to seawater if left bare and open to the air.
Booms usually break at the vang attach point because of the (foolish) use of stainless fittings by many rig builders. That wrap around spreader attachment is not one of the good ideas for longevity. Pretty and shiny though heavy, corrosion prone and complicated.
Stainless backing plates are also a terrible idea. Use alloy.
Ok, paint it is. Seeing you work in aerospace, what is your opinion of titanium chain plates? The environment here is so corrosive, it is something I am considering.I've always liked the traditional look of a white painted mast. The couple of mils of paint thickness will protect it from weathering without adding much of anything in weight. I work in the aerospace industry and all of our aluminum parts are completely anodized then any exposed surface is also painted for additional protection. One of my friends is trying to talk me into doing next year's Pac Cup so perhaps we will bump into each other?
Stop.So instead of re painting my entire mast, I could strip all paint, buff it and leave it as is? Where fitting contact the mast, I would use proper isolation between mast and fitting to reduce corrosion.
Well so far so good. Had some time tonight to remove the spreaders from the stainless fitting/sockets. They came out without much difficulty. Worked back and forth while flushing with water. The spreaders looked good with only minor surface corrosion in areas, but about half of the original paint still intact. Interesting thing is that there was no sealant at all between spreaders and sockets. May be a good idea, as if there was sealant, and the seal broke at the top, the entire spreader could fill with water and not drain, leading to major corrosion. So maybe best plan is to coat everything with lanolin and not try to go for a water tight fit.On another site I found this comment:
"Some of the S&S 34's have a s/steel band at the spreaders with sockets for the airfoil spreader bars. Some of these where beautifully crafted from the guys at a Taskers. But 30 years of Ali in stainless and the spreaders might not be too flash. Here is a picture of some pullers I made to pull spreaders out of the sockets but in this case the spreaders where so corroded that the socket had to be split to get the rotten spreader out."
Luckily my spreaders are loose in the sockets, so they should pull out no problem. Curious as to how the poster got the fitting off the mast- I sent the poster and e-mail asking this question.
The poster also said he sanded the mast down to bare aluminum, polished and left that way with no painting. So what is the purpose of paint? Could I just remove all the paint and leave bare? After all the inside of the mast is bare aluminum and it sees water and salt- especially at the base.
Here in Hawaii it is big money and a lot of my time and effort to take the mast down. Had a truck mounted crane to take it down an trailered it to my house to work on. Quite a job with a 43 foot mast. I don't plan to take this mast down again for at least 10 years. I would think lanolin would be good also. One thing is not good is to have water setting in a small space where capillary action keeps it there, as would happen in these spreader sockets and mast fitting. All in all I think the mast has held up well. It has done a circum-navigation, been knocked down with spreaders in the water, and is the same mast design as used by Jon Sanders, whom did a 360 degree roll in the southern ocean while on non-stop double circum-navigation.My sense of things is that the fit between spreaders and their sockets tends to be fairly loose. Probably any water that gets in will find it's way out. Although, with only half the paint left in there and some surface corrosion, obviously something's happening.
Maybe a layer of mylar around the spreaders inside the sockets, if you don't mind more unsolicited advice? It's not just the water, it's the dissimilar metals in direct contact.
If you lower your mast every couple years or so, the spreaders will be easy to pull, check and renew whatever you put in the sockets. Either way, you're wise to be looking at this stuff.
Then all bets are off. Good luck with it.I don't plan to take this mast down again for at least 10 years.
I would not say I need luck, I can tell quite a bit about rig condition by going up the mast and doing a close inspection. Interesting I would say this is probably the first time in 37 years the spreaders have been taken apart and structurally they look nearly new. Interesting also most of the wire and turn-buckles on the rig are originally. And the turn-buckles are of the tubular type that collect salt water and corrode with out you ever knowing because you cannot see inside- scary. I will replace all standing rigging and would plan to that in the future at 10 years or as needed based on inspection, or over stressed rig situations. In any case, there are risk to taking the mast down, a dropped or damaged mast could cost me $20k or more for rig replacement, so one needs to weigh the benefit of doing things. If I needed to shell out $20k, my wife would probably put an end to my sailing, as she would if I spent the money to pull the mast every two years.Then all bets are off. Good luck with it.
I'd suggest not caulking the bottom edge as it's nearly inevitable that water will eventually find a way in and it will need a way to drain out.The corrosion seem to be located where pockets of water were collected and held by the silicon caulk.
