1 - 7 of 7 Posts
Discussion Starter #1
I bought this motor used from a good dealer. 2013 Mercury 4HP. It runs perfect. The problem is it locks up when I pull start it. Talked to the dealer and he said there is a hydra lock or something and I should pull the cord slowly full cycle than start it normal.. Well sometimes it works fine but a lot of the time the lock stops the cord short even after I have cycled it through. Than It takes a LOT of short pulls and the motor has actually started on a slow pull or even a short pull. If I pull the cord slowly it doesn't lock up. I'd have to say 70% of the time it causes me problems.. Other times it's perfect. The dealer is a ways away from me so before I drive back there does anyone have any suggestions.
The Merc 4 uses a Tohatsu 'power head'.
The problem as you describe most likely is the *interlock* between the recoil starter and 'gear shift' is out of adjustment. This interlock prevents pull starting in either forward or reverse gear position but not neutral.
Id recommend that you jiggle the *gear shift* lever positions back and forth and in small increments, while slow pulling the recoil starter to possibly locate where the interlock does not engage
There is a Tohatsu SERVICE MANUAL "4 Stroke MFS - 4/5/6B,C Models" that should contain the adjustment procedure ... the manual is available from most 'brick & mortar' and also online/internet Tohatsu dealers. Should also be available (Mercury 4 Service Manual) from most Merc online dealers.
Purchase your service manual based on the Model, serial number, and YEAR purchased.
If you are an experienced DIYer, you can probably, remove the engine top cover ... examine the shifting mechanism and linkage, find the problem and fix it yourself without the need for a manual. Just remember that the interlock 'set point' is: 'Center' of the neutral (shift lever) position allows easy/full movement of the recoil starter mechanism.
Without seeing this OB, my first guess would be that the recoil starter assembly has come slightly loose on top of the power head. I would also guess that this OB has been fully disassembled or possibly 'rebuilt' and the mechanic forgot to put BLUE LOCKTITE thread sealer on the screws threads that mount the recoil starter - just a guess.
Discussion Starter #7
I just looked closely at that area. That IS the problem. If I gently hold it forward the pull start is normal. It does seem a little loose. I'm going to try to tighten the screw that holds the plastic piece to the recoil. I'll also re visit the service manual. I didn't see any procedure for that but most likely overlooked it.
Thanks to you and everyone very much for taking the time tp answer my post.
1 - 7 of 7 Posts
