1 - 6 of 6 Posts
s/v Ubiquitous
I need some help. Previous owner of a 26 foot boat that needed a cutlass bearing replaced. Easy peasy because it was within the hanger supporting the shaft. The Morgan is not built like that. The prop comes directly out of the hull in front of the rudder. Pulled her out for the first time today and there is some movement in the prop shaft. Not really bad sloppy but enough I want to change the cutlass bearing out.
Here is the delima, never done or saw one done this way. I know there are other boats like this. How do I go about removing and replacing the bearing? Would so love to get my hands on a copy of the owner manual for her.
Thanks for any help,
Bill
Tartan 27' owner
So the cutless bearing is in deadwood, like mine. No strut.
You are in for some fun!
This is how my cutless bearing project went down in 2011:
2011, November 30th. Begin drive train rebuild | Odalisque
Best advice I can give you is to get hold of a Sawzall with a few new, sharp metal blades. We used the Sawzall to cut the cutless bearing in order to remove it And to cut the shaft in half, making the whole job much easier. A new SS shaft was < $300 and we were back in business with a brand new drive train.
Have any idea how old your prop shaft is? or what material it is made from?
Ours was original (from 1967) and bronze and was worn at the stuffing box junction. Once we found the wear on the shaft it was easy to say "cut 'er up".
Consider replacing the shaft log tube too while you are there if it looks original. Be ready for the "cutless bearing job" to blossom into the "drive train job".
Good luck.
s/v Ubiquitous
Discussion Starter · #3 ·
Thank you for the response. I don't doubt you succeeded in this but I have to back up and ask, WWMD (What would Morgan do?)
It seems odd to me Charlie would have made a boat that required cutting part of it off to replace something like a bearing that is known to need replacing eventually. There has got to be another better way.
Tartan 27' owner
Well, looking at the line drawings of the Morgan 35' I'm not sure you can remove your shaft without dropping your rudder first.
MORGAN 35 sailboat specifications and details on sailboatdata.com
With your shaft removed you can easily remove your old cutless bearing and install a new one. In order to remove your shaft you will need to disconnect the flange from the tranny and remove the flange from the shaft, then slide the shaft out of the boat.
You may want to consult with a local boat yard though. Some may have the specialized tools to remove and replace the cutless bearing with the shaft still in the boat (requiring only the prop to pulled off the shaft). I'm not sure about this though so check around.
I'm not convinced that old Charlie had a better way of designing an engine propulsion system than anyone else but I am curious if you do find a "better" way.
s/v Ubiquitous
Discussion Starter · #5 ·
Looking long and hard at it I have formulated this plan.
Ignore it. (jk)
I would really like to and I don't really motor that much so, while the idea has not been entirely thrown off the table it is still possible. We will be pulling her out in a year or less to evaluate the bottom after my hull refurbishing currently in the works.
So if I do tackle this replacement now I hope it goes like this
Remove prop
Remove prop coupling
seperate prop shaft from coupling
remove rudder
remove prop shaft
remove old bearing and replace with new
replace prop shaft and connect with coupler
replace rudder
replace prop
Drink several beers
Am I missing anything...like while Im in there doing all this add to my list
replace packing gland on rudder
replace packing gland on prop shaft
change tranny fluid
change oil
vacuum and repaint engine hold and bilge
-did I miss anything?
Tartan 27' owner
Your plan sounds about right to me Bill. It is quite a bit of work just to replace a 4" long bearing but fortunately it should last a good long time.
In the "while you are in there" category you might consider:
- replacing the shaft log hose (Buck Algonquin hose behind stuffing box) & hose clamps
- have shaft checked for true by prop shop
- have propeller spun by prop shop to verify balance is true
- if re-using shaft coupling have it "fit & faced" by prop shop
Best of luck with this.
1 - 6 of 6 Posts
