I have been "pondering" adding a tabernacle to Tundra Down for a couple of years now. With the help of Ed and Ellen Zacko I am on the verge of cutting out the pieces of aluminum that will be welded together and become the mast's new base. Part of the process that hinging the mast requires is careful alignment of the "hinge pin" that runs through the tabernacle and the mast and the top of the uppers' lower turnbuckles. That isn't my concern here. What I discovered when building a mockup of the tabernacle is that the attachment point for the lower end of the upper (at the chain plate) is not centered on the mast but is just 1" from the forward edge of the mast. I stretched a tight line between the opposite chain plates and found where it crosses the "base plate" (mast step) on the deck. (Red pencil in photo)
I have Bob Perry's plans for this boat. As one would expect it shows the upper centered on the mast, fore and aft. It is a drawing? I would like to move the center of the mast's base forward an inch or so in the new tabernacle. It would still be at least an inch forward of the mast's actual center line.
Moving the location of the mast's center forward an inch or so has other considerations. Wiring will no longer pass through the deck under the mast's base. It will exit the mast and I will use Bulgin hardware to route wires. The I-28 has an unusual solution for supporting the compression post. (I think the original design had the mast stepped on the keel?) Because of this, the post itself is oddly configured. I will need a stronger platform for the tabernacle because of the upward forces on the base involved in raising and lowering the mast. Increasing the number of anchoring machine screws from 2 to 4 will requiring a modification to the compression post's top plate. Routing wires inside the post is no longer an issue.
What do you think? I don't see a reason not to. Modifying the compression post is a must.
