1 - 5 of 5 Posts
· Read Only
Hello all,
I have a Dufour 1300 quarter ton racer. Similar to the j-24, the traveler cuts right through the cockpit. I was in the process of moving it behind the tiller when I was told that the angle from the boom end to the traveler should not be greater than 90 degrees. Are there any riggers out there, and is this true, and if so, how important is it? Thanks for any informed responses.
Well
I am not a rigger BUT i can see were there may be some problems with the main sheet if you move it back 2 feet
On the South American J24 they moved it forward to open up the cockpit and went to mid-boom sheeting
Jd, in reality, they should, but if the angle is not that much greater there is no reall issue, but..you will lose some of the tension force , in full in main sheet.
What happens when the angle is greater, is that after you sheet in as much as possible, the sheet no longer tries to pull the boom downd, but starts pulling it backwards.
The King 40, by Summit, has the arrangment you are seeking for and they are ok with it. Its 95 degrees or so.
If you are desperate. you can do it..and the only reason is because you have a traveler. How big is the one you want to instal? Because if the traveler is big, by moving the car you can compensate for that, but yo will lose a little of the characteristics of the system. Use only Dyneema if you do that
MAke sure the gooseneck can take the pulling effect.
See this site and serach in the galleries, you can see the King 40 and the 100 degree sheet..they made the boom 2 feet longer than the sail for that
The King 40 | Summit Yachts
Alex
· Read Only
Discussion Starter · #5 ·
Thank you all so much for your input. I found a picture of a Dufour 1300 in Germany where they moved the traveler to the same spot I'm going to. It looks like they might have extended the boom. I'll measure the angle, and if it's not too great, ~95 degrees or so, I'll just go ahead. Otherwise, I'll look into extending the boom or buying a new one. Again, thanks to all who replied, I greatly appreciate it.
1 - 5 of 5 Posts
