Here's a illustration of a monohull pitchpoling... not quite the same as what happens on a multihull, but close enough to give you an idea
Well, if the hulls are used as feet for deck structures like the SWATH....
So they all could be of the same design, and with the big deck structure it's easier to have them rigidly fixed. Virtually a big ship on four feets. I guess it would be very big for better deck to hull structure ratios, and many tension structures.
I have a kind of hybrid trimaran, a Corsair 36, which I have fitted out as a liveaboard. Space is a bit tight at times, and docking does have to be carefully arranged, due to my 29.5-foot beam, as CBinRI alluded. It has been a bit of work to make it a liveaboard, as I have hull 16, but I think it has been worth it, and it is nice to be able to sail in small puffs of wind when others are motoring their sailing vessels. There are some other features that have not been mentioned about trimaran handling, which I have learned through experience. Since there is not much hull under water, turning at speed is great with the daggerboard cutting into the water, but at low speeds, you are at the whim of the currents and wind, since there is not much area directing the steering. Also, at anchor, my trimaran moves with the wind, not the current, so at places like St. Augustine, as the other boats orient north-south, I found that I was oriented east-west, and other boaters do not anticipate this when anchoring nearby. Also, I tend to sail a hull at 7 knots, and at 16 knots the windward ama is about 3 feet out of the water, which means that anything not tied down is in the passageway. I really enjoy her, and every day is a learning experience.
I didn't realize that. I guess it's a trade off for the necessary bow design of multihulls.An arrow configuration for a trimaran would be a disaster.
On many trimarans, the forward buoyancy is really supplied by the amas, not the main hull.
I see. Yeah, relatively more boyancy makes it too light for the elements.Also, at anchor, my trimaran moves with the wind, not the current, so at places like St. Augustine, as the other boats orient north-south, I found that I was oriented east-west, and other boaters do not anticipate this when anchoring nearby.
dog you own a telstar and i dont know if you have been in a corsair 28, but it looks like they have more room in the corsair. do you feel the same?
now i do like the tri look but the space issue is a turn off for me. i would love to see performance sailing give the telstar a v berth. heck my 27 foot hunter is a lot bigger inside. i saw the corsair is a alot pricier, but i would think if PS made a 31 or 32 footer with a v berth ( basicly a more mono hull interior layout ) and could keep the price under a 100k the would sell the heck out of them. what do you think the extra 3 or 4 feet would add to the cost?
i do like the layout of his design. do you know what they run?
as for for being 5'4" that makes you a sailing puppy
also i will be up your way this weekend, i have to go bury my grandmother in yarmouth. how is the weather?
Scotty , feel free. My 'specifically' was not meant to be exclusive of others but I did want SD's take on it.TDW you did not ask me weither tri or cat but i will answer anyway.
Chris White's designs have fairly nice interiors...this is the interior of one of his Hammerhead 34 trimarans.Have just spent a few weeks wafting around Jervis Bay (south of Sydney) where the only all weather anchorage is up Curumbin Creek with less than 1.5 metres over the bar at times. Not surprisingly there are an awful lot of multis in that neck of the woods.
Seawind factory is not far from JB and there are a fleet of them down there. Certainly they look the goods from a distance, give every indication that they sail quite well and that they have more than adequate accomodation.
Now I am not specifically anti multihull. Yes, all my boats have been mono but if I felt a multi suited my needs I'd have no worries going with one.
My major negative is that many (if not most) of the modern multis have interiors that are horridly plastic. Imagine2Frolic's is one of the nicest I've ever seen but some of the others...blech !!
Yes, the problem of weight and all that stowage space is a common one. Having the space tempts one into filling it...causing the boat to be seriously overloaded. Restraint is key to keeping the boat light.I'd think also that one of the multis biggest drawbacks is size. It seem from what I read that anything much under mid to late thirties (feet) is not all that desirable. A forty foot cat for two people is an awful lot of boat, a large part of which is simply taken up by a plethora of berths which you cannot use for storage due to the need to keep weight out of the bow. Any comments of that ?
I'd probably go for a Chris White designed Atlantic 42 catamaran. Its a beautiful boat with lots of space and moves like a bat out of hell. The pilothouse design gives a very sheltered interior helm position, and the cockpit, located just aft of the mast, gives a very secure location to operate the boat from, even in heavy conditions.Specifically to you Dog......ignore the fact you own a tri......if money was no issue....Cat or Tri ? I am talking live aboard cruising here...not for a weekender, not for a marina bound floating condo.
They really don't require it from what I've seen.Generally.....why don't multis have gimballed stoves ? I realise that they don't heel like a mono but even so I would have thought that on any small craft a gimballed stove would still be a good idea. Thoughts ?
The multihulls I like don't have a curved settee...not a one.Last but not least there is also a distressing tendency for cruising cats to have curved settees in the saloon. Useless horrid damn things they are. OK so when you are tied up to the dock they might be tolerable but I cannot for the life of me understand how anyone can get seriously comfortable on a curved settee. Maybe it is just me but I like to to be able to lie down not sit on a boat other than when eating. I may be bent but I am not curved.![]()
Dog and I have a shared affliction for those Chris White Designs, especially the Atlantic series. I find them almost bewitching. I much prefer the forward cockpit design, too.
If I ever switched over, and could afford it, I'd be looking for a Chris White designed cat. My current favorite is the A48, which is the smallest one to offer the aft deck (last I checked).
