1 - 18 of 18 Posts
I am looking at buying a Newport 33. When under power she seems to pull excessively to port. The broker says, "Don't worry about it, its normal. Due to prop wash." Which I could understand. However, I have found the sellers broker to be less than credible on several issues. As a result, if he told me the sky was blue and the sun was out, I'd check twice myself before believing him...
If I had to put a number on it - I would guess the pull would measure a constant 3 to 4+ lbs on the wheel - measured at its outer edge when running at about 2500 rpm, maybe about 6 kts.
The boat comes with a Navico WB5000 autopilot. However it does not appear to ever have been used. The belt is too big for the setup. But I wonder if it would work under power with that constant pull to port.
Anyone familiar with the range of expected pull to port on a N33?
Rich McManus
don't post multiple posts on the exact same subject. i doubt it is prop wash.
if the survey did not find anything i have one question who surveyor did you use, hopefully not the brokers. did the surveyor look at the boat out of the water?
if it was your surveyor, tell the broker to pull the boat again, and stand behind her and make sure the rubber is centered with the keel. same with the prop shaft incase the strut is bent. a cost of a 125 bucks to sell a boat is nothing to the broker
Discussion Starter · #9 ·
How's this for a guess.
The former owner kept maintenance records. I read the history. Not long ago the owner had the transmission replaced. Shortly thereafter the engine ran dry of oil! Seems the mechanic rolled a gasket and the oil leaked out while under power. Insurance paid for the original mechanic to pull the engine and have it rebuilt. (rebuilt by the same guy that caused the problem!).
When she was out of the water for the survey I remember looking over the rudder pretty closely. If it had been out of wack significantly - I think I would have noticed. The rudder is exposed on these N33's. There is no skeg. I didn't notice any dings on the rudder or keel.
But I'll bet the mechanic that couldn't get the gaskets strait, couldn't get the alignment strait. Would that make sense?
Rich
Not to mention, if the engine wasn't properly aligned, the cutless bearing would be getting badly worn...
One of None
Hunter 34
I agree on the alignment. since we replaced the cutless bearing and installed the PSS seal my boat was pulling to the port heavily while under power. I'm planning on getting more help aligning the shaft as soon as weather permits,
With balanced spade rudders it's not unusual to have a significant "pull" one way or the other under power. It is in fact caused by the prop wash, and the way it is acting on the "balancing" tab - ie the area of the rudder ahead of the rudder stock.
The degree of this pull is affected by the balance area and the proximity of the prop to the rudder. It can be quite strong, esp if the rudder is on the verge of being over-balanced.
We discovered this first hand some years ago with my brother's Ranger 28. It had an unbalanced skeg rudder that had extremely heavy weather helm under sail and the boat was a broach machine. During a refit we cut off some of the skeg and added it to the leading edge of the rudder to create some balance forces. Unfortunately we overdid it a bit and, while that resulted in much improved rudder balance under sail, under power the pull on the tiller was excessive (previously there had been none). The balancing area we created was just a few square inches more than what the factory did in later models, but the effect was noticeable.
So this pull on the N33 may be "normal", it would be good to get some input from other actual owners.
Discussion Starter · #14 ·
Things are looking up. Another broker (not the seller's) turned me on to a local mechanic who is very knowledgeable. Turns our he also owns a Newport 33. We discussed the issues and are going to meet in the morning for a test spin and inspection. He'll be able to contrast 'normal' to the behavior of his boat.
rwm
This is most probably to unclean bottom. When a boat is kept in water staying in the same place, one side might catch more organizims than the other. The main reason is the sun. The sun effects growth. If there is something wrong with the propellor, shaft or the rudder the rudder will not be loaded on one side but the boat will travel sideways without any load on the rudder.
If the boat is in the water now it means the bottom is cleaned. Recheck it.
Discussion Starter · #17 ·
It shouldn't be growth. It pulled to port both before and after we hauled her out. On the haul out we had the bottom pressure washed.
I'm meeting the mechanic that owns a N33 in the morning. We'll see what he thinks.
Thanks for everyones thoughts. I'll update all after our test in the morning.
rwm
Discussion Starter · #18 ·
Well, just came back from a detailed inspection of the engine and boat with a very detail oriented mechanic who also owns a N33! He inspected the engine and noted some minor issues. He listened to the engine at various throttle settings and under load. We took the boat for a test spin. He thought the pull to port was similar to that he experiences with his N33. He noted he normally motors with a throttle setting at around 2100 rpm. We had been motoring with the throttle at around 2400 to 2500 rpm. Since I would emagine that the force against the rudder generated by propwash would increase by some proportion to the square of the velocity - the force was far greater at the higher rpm. So what he saw didn't concern him.
The prop shaft seemed well aligned and turned freely (if it was significantly out of alignment it would have bound in the cutless bearing).
The mechanic also knew the mechanic that did the work prior and spoke well of him. He thought all was well other than some minor issues.
So - I'm going to buy her.
Thanks again for everyone's thoughts.
rwm
1 - 18 of 18 Posts
