1 - 5 of 5 Posts
i am in seattle and
just bought an islander 30, beautiful boat. couple small issues i am wondering
about, when i run a space heater off shore power the switches for each outlet
get hot, well at least warm. strange, i am thinking maybe a loose connection
but it is on all three. also there is water that collects on the deck of the
forepeak, but i can't find a trail of wetness to see where the leak is, shroud
sound reasonable, through the hanging locker? i've read a little about the
islanders compression post crushing the deck in the cabin, doesn't look like it
has happened to mine yet, is it true and should i put some shims down there as a
preventative measure? shroud tightness, i've always been paranoid about deck
stepped masts and wonder if there is a good way to make sure the shrouds are at
the right tension. any other tips for increasing the storage space? boat
handling? my slip i have to back out of, into the wind, and its been a little
hairy a couple of times. oh, one more, engine access, anybody have any ideas or
tricks for working on the engine? oh, really one more, plumbed for hot water
but hot water heater is not installed, opinions on what would be appropriate for
this boat? thanks all for any thoughts you might have. this is my second boat,
my first was a haida 26, great boat but i got it for a song and didn't feel like
putting any work into it was worth it, this islander is the nicest thing i've
ever owned and i would like to keep it nice. what are peoples haul out
schedules and routine maintenance? (snuck one more question in there) anybody
else on here from the puget sound? my plans next i think are an autopilot, fix
the depthsounder, and maybe a windlass and dodger. y'all think that makes
sense? thanks again.
Merlin
Merlin,
As the owner of a Bahama 30 for the past 12 years, I may be able to help with some of your questions.
Could the water you're seeing be coming from the forward opening ports or the hatch? When we first got our boat, I believe it had the original opening ports and they leaked badly. We replaced them with Lewmars and have had no problem since. The hatch isn't a particularly watertight design, and needs good weatherstripping or similar to stay (semi-) watertight.
I'm aware of the compression post problem on the B30, but ours is fine. Our boat is a 1980, and perhaps the factory corrected the issue by then - I know that they became aware of it at some point. I'd certainly monitor it.
We keep our upper shrouds quite tight, and the lowers a bit less tight. The main thing is to keep the mast in column when heeled over in a breeze.
We haven't added any storage space, but there's a lot a space under the starboard settee for food stores, and storage for large items in the port seat locker. Our family of 4 has gone on several week-long trips on the boat. We bring so much gear, food and junk that the waterline goes down by a few inches, but we always have plenty of space - we use the quarterberth for personal gear.
My best tip for engine access is to become a contortionist :). Do you have an access hatch in your quarterberth? Between this hatch and the forward end access you can get at pretty much anything, but it's not easy.
We have a 6 gallon rectangular water heater mounted under the forward end of the quarterberth, near the batteries. We don't have the engine water plumbing hooked to it, so it only operates on 120VAC. We found that with the raw water cooling system (assuming you still have the original Volvo), the saltwater gums up the guts of a water heater pretty quickly.
We have the bottom cleaned monthly here in So. Cal, where things grow pretty quickly, and haul the boat out for bottom painting every 3 or 4 years. As far as maintenance, we just change the oil & filter every 50 hours (again, assuming you have the Volvo - other engines might have a different interval). Fuel filters need to be changed occasionally, although we don't have a regular schedule for those. Incidentally, I'd recommend adding a secondary fuel filter/water separator such as a Racor if you don't already have one. Also, keep on eye on the water pump impeller and always have a spare on hand.
We have a dodger that we keep on at all times, and it's pretty nice when conditions gets rough - a lot of spray gets back to the cockpit. We don't have a windlass. It would be nice, particularly if you do a lot of anchoring, but they are a big draw on the batteries.
Enjoy your boat! We've had a lot of fun with ours.
-Roger
Merlin,
I have a 1974 Mk II and I can relate to the engine access. I cut a nice sized access panel in the quarterberth. I can get to almost every part of the engine but the water pump. It's a palmer P-60 gas engine. My boat has had some minor hull compression where the mast steps and was corrected by shoring up the compression post once the mast was removed.
Hope this helps,
Jerry
1 - 5 of 5 Posts
